i have some tips on how to install sim card on your cellphone:
Install SIM card 1. Make sure that the cover of the connector panel is closed. 2. Slide the phone open. 3. Open the SIM card compartment (1) on the back of the slide 4. Slide the metal SIM card holder towards the compartment lid to release it (2). 5. Open the SIM card holder. 6. Insert the SIM card in the holder as shown (cut corner at the upper right).
7. Close the SIM card holder, and press it down slightly. 8. To lock the SIM card holder, slide it away from the compartment lid (1). 9. Close the SIM card compartment (2).
sir, just follow the steps below, 1. Switch off your phone... 2. Remove SIM card & memory chip... 3. Now press & hold keys - 3,*,call green) ... 4. Then without leaving these three buttons press power button... 5. Formatting task will be started... 6. Remember its a very rare trick.... sir please rate my answers too
ITS INSERT SIMS PROUBLEM FIRST CHANGE YOUR SIM CHEK CONNECTION PACKING CHECK SIM SOCKET RESOLD IT THEN SIM ICS PROUBLEM HIT SIM IC CHANGE SIM IC JUMPER SIM IC OR CHANGE IC
First Option: please change Phone in the Other Sim and check the Phone Network If Phone Network Not Solved So Secend Option: Your Phone Network IC Fault So Please change Network IC I Hope Network Problem will Solved IF Not Solved So
select network manualy in your handset. or contact nokia care
hi im josh in cebu phils. may i help you? As a mobile phone techinician, Friend i will say that the problem centers on your phone and not on the sim card. You phone is locked to the network of that SIM or commonly mentioned "not open line" thats why the software or the phone doesn't recognizes the SIM you are using because it is locked. To solve this problem you may go to your network provider and ask for assistance of opening the line of your phone so that you can use any sim cards you wanted. and your phone will now be unlock or "openline".Thats all friend hope i helped you good luck
Hi have a repair shop, and you know it’s a very common problem on this model.90% of the cases I found liquid damage in the phone damaging the Sim Ic, it’s a little square one near your sim reader, you can also clean around that with a soft tooth brush and mentholated sprits.Don’t fiddle with your sin contact/ reader if no damage visible to the eye.
I had the same problem with my girlfriends 6111. I managed to fix the phone, but i did have to open it up myself and get a new ribbon cable to replace the damanged one. Basically one of the springs had been pushed the wrong way and this was acting like a scissor action on the ribbon cable for the screen. It cuts part of the cable so no image can be seen but power is still sent, thats why it only powers up white. Doing this yourself will void the warrenty but the warrenty on this phone had expired and i was being quoted £35-£40 to get it fixed. I managed to do it for a fraction of the cost!!!
