Sony VAIO VGN-A690 Notebook Logo
Posted on Nov 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I wish to install new Memory slot in my sony laptop VGN-A417M, Where is it situated in my laptop and how do I get into it. Thank you
Anonymous
Level 3:
Master:
  • Master 362 Answers
  • Posted on Nov 20, 2010
Anonymous
Master
Level 3:
Master:
Answers
362
Questions
0
Helped
66765
Points
1092
Located on the bottom of you pc its a small panel with the ram symbol on it it's held with a phillips screw or 2 turn off your pc take out your battery then hold onto to something to drown out any static from your body then they are held by small clips on both ends of the stick they will pop up on a 45% angle then remove, replace and enjoy and try to match speeds of ram for better performance hope this helps
Vram is 256 mb but dedicated is 64 mb and shared is 192mb . how do i change it.. no option in bios also. Sony vgn n220e
You should not change this. Laptops have small video chips and often depend on "shared" memory to achieve good performance without overheating. Basically, the video processor borrows some of your installed RAM memory. Also, your laptop may have been supplied to you with less total RAM memory than the maximum and you can add more memory. In Windows, click on Start then right-click on Computer and select Properties. In the Properties window you can read how much total memory is installed. 2GB (2048MB) is a desrirable amount for Windows XP. Windows Vista and Windows 7 can benefit by having total 4GB of RAM memory. Check your Sony user manual for instructions on adding more memory. Basically, you turn off the laptop, remove the battery pack and unscrew a small cover on the bottom of the laptop to access the memory slots. Usually, there are 2 slots here. Ideally, you should install a matched pair of memory modules (a "kit") for peak performance. However, quantity of memory is more important than having matched modules, so if one slot is occupied and the other slot is empty you may simply buy one more module and install it in the empty slot.
1helpful
I can't find the second memery slot A417M
LOL, what kind of laptop? I'll bet the bank it's a Sony Vaio. OK, even if i'm wrong some manufacturers didn't put much thought process on ease of access on certain components. Your 2nd memory slot is probably either under the keyboard or under the palmrest either to the left or right of the touch pad area. That means you'll have to do a partial disassemble to get to it.
1helpful
3answers
I cannot find the second memory slot on the sony vgn-a290 laptop.
The second slot is under the keyboard. There are three small clips at the front of the keyboard. You can release them with a small screw driver.
2helpful
Added memory to laptop, nothing on screen now
remove the memorys and check the memory slots for any damaged pins .test the memory one by one on 2 slots(power off place one memory on slot1 and power on then do that procedure on slot2 ) if the laptop boot, one memory or one slots have problem and you can work with another one ,if you didnt see the boot screen at all try to reset the Bios .
if still dont work have to repair or replace the mainboard.
1helpful
I can't find the second memery slot on sony vaio vgn a790
Second memory slot is under the keyboard. If you use link below and select 'user guide', then go to page 148 and it gives you detailed instructions on how to access the second memory.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=VGNA790
I would appreciate feedback if this is useful. Thanks
Memory card reader on new VGN-SZ480 doesn't work
Yes it is really plug into slot and use but it won't work at all if you won't install drivers. So please go to Sony's website and choose your model there and then download n install drivers. Thats it. Simple or not ?
10helpful
5answers
Ethernet drivers for sony vgn-fs115m
Hey MIDO Try This Tool
VAIO Launcher 1.4.11 Update Program
This program will update VAIO Launcher pre-installed on the VAIO model listed below.
VGN-S4HP/B
VGN-S4HRP/B
VGN-S4M/S
VGN-S4XRP/B
VGN-S4Z/S
VGC-V3S
VGC-V3M
VGN-FS285H
VGN-A497XP
VGN-A417M
VGN-A417S
VGN-FS295XP
VGN-FS215Z
VGN-FS215M
VGN-FS295VP
VGN-FS215B
VGN-FS215E
VGN-FS215SR
VGN-FS215MR
VGN-FS285M
VGN-FS285B
VGN-FS285E
VGN-FS215S
VGN-B3XP
VGN-B3VP
VGN-S4XP/B
VGN-S4VP/B
PCG-K415S
PCG-K415B
VGN-FS195XP
VGN-FS195VP
VGN-FS115S
VGN-FS115Z
VGN-FS115M
VGN-FS115E
VGN-FS115B
VGN-FS115ZR
VGN-FS115M -- ( Thats Ur MODEL)
VGN-A397XP
VGN-A317S
VGN-A317M
VGN-S3XP
VGN-T2XP/L
VGN-T2XP/S
VGN-T2XRP/S
VGN-S3VP
VGN-S3HP
VGC-RA304
VGC-RA204
PCV-RS704
PCV-RS702
VGC-M1
VGC-V2S
VGC-V2M
VGN-T1XP/L
VGN-T1XP/T
VGN-B1XP
VGN-B1VP
VGN-S2XP
VGN-S2VP
VGN-S2HP
VGN-S2XRP
VGN-S2HRP
VGN-A297XP
VGN-A295HP
VGN-A217S
VGN-A217M
VGN-A215M
VGN-A215Z
PCG-K315Z
PCG-K315S
PCG-K315B
PCG-K315M
This update resolves the problem of registered applications not launching from the VAIO Launcher toolbar.
Note: This program requires VAIO Zone 1.2.05 or later. If your VAIO model comes with VAIO Zone 1.2.02, you must first update VAIO Zone before running this program.
Download and installation
1. Download the file SOAVZN-01028300-UN.exe and save it to a download directory
2. Close all running applications
3. Go to the download directory and double-click SOAVZN-01028300-UN.exe
4. The InstallShield wizard starts
5. Click Next and wait while setup is installing the new software
6. Click Finish when the installation is complete
HERE
2answers
Sony A690 Memory Location
Some Vaio laptops (and some HP's) have a memory slot under the keyboard.
Sony VGN-460 Memory & CPU Upgrade? Noisy Fan How do I replace it?
The Crucial website suggests you can put 1GB in each slot. http://www.crucial.com/uk/store/listparts.aspx?model=VAIO%20VGN-S460%20Series Sony might know which CPUs will work with this. Hopefully any Pentium-M with 533 FSB.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
