Oil pressure can be checked at the sending unit passage with an externally mounted mechanical oil pressure gauge. To get accurate results from the test, make sure you follow the manufacturer's recommendations and compare your findings to specifications.
Testing the Oil Pressure Gauge
Testing Oil Pressure
Pressure can be tested by temporarily installing an oil pressure gauge in place of the sending unit. Before testing, look up the oil pressure specifications for your vehicle in the appropriate service manual.
An oil pressure sending unit is removed with a special socket. Courtesy of Chrysler Corporation.
WARNING
Be extremely careful when working near a running engine. Always wear safety goggles or glasses with side shields when working around moving machinery and be sure that your clothing is not loose.
SOURCE: oil pressure switch
Lower Right Hand Side, Front Of Engine, Below the Power Steering Bracket
I’m happy to assist further over the phone at https://www.6ya.com/expert/jonathan_3a3c556b4b17d1d2
SOURCE: oil pressure sensing switch location
The oil switch is located on the passenger side of the truck in the back of the engine. Look for the transmission dipstick, then feel for it between the transmission dipstick and the engine block. It is hidden pretty well, but a socket wrench will fit to take it off. The new part uses a 1-1/16 socket, the old part for some reason was smaller, I think 13/16 inch. Hope that helps.
SOURCE: location of oil pressure switch on a 1997 cadillac deville
Oil pressure switches a normally located by or near the oil filter on all cars. :-)
SOURCE: location of oil switch 2002 chrysler 2.7 engine
should be on driver's side right above the oil filter
Fig.: Oil pressure switch (sending unit) schematic
The low oil pressure warning lamp will illuminate when the ignition switch is turned to the
ON
position without the engine running. The lamp also illuminates
if the engine oil pressure drops below a safe oil pressure level. To
test the system, perform the following:
