0 I am the owner of a Samsung D900i and it is dropping signal some times, what could be the cause. some one told me that it need to be flash, but i do not have the software
AnonymousMar 27, 2014
Limited service problemLimited service problem
You can't post conmments that contain an email address.
Hi
the version software that came with your phone, PC studio is not compatible with Vista. However here is a link that you can download the version that is. It will be same cable.
try going onto the samsung website and follow the links you should be able to download the software, if not go to a phone shop and they might be able to help you further...
Locate the application executable. Right click the executable and click the Properties option. Select "Compatibility" tab. Select the "Run This Program in Compatibility Mode" option. From the drop-down list, choose the operating system you ran before upgrading to Vista. If you did not upgrade, choose windows xp. If necessary, select the option to run the program as an administrator, if you are logged in with a restricted account. Click OK.
Try to run the program again, if that does not work, contact the manufacturer to find out when a release for vista will be available.
Download the Vista-version of the Software and Drivers from your local Samsung website.
The english version can be found here :
http://www.samsung.com/uk/support/productsupport/download/Model_Select.aspx?type=&typecode=100100&subtype=&subtypecode=100101&model=SGH-D600E&filetype=SW&language=
0
