The beeping sound you are hearing from your Teka DW8 55fi dishwasher is likely related to the "Eco" light. The Eco light is an indicator that the dishwasher is running in the most energy-efficient mode. If the light is flashing, it could indicate that the dishwasher is experiencing a problem with the eco cycle and needs attention.
To troubleshoot the issue, you can try the following:
Check if the dishwasher is loaded properly and that there are no obstructions blocking the spray arms.
Make sure the dishwasher is level and not vibrating excessively.
Check if the dishwasher is properly connected to a working electrical supply and that the circuit breaker has not tripped.
Clean the filters and spray arms to ensure proper water flow and performance.
If the problem persists, it may be necessary to call a professional for repair or contact the manufacturer for further assistance.
Please note that these steps are general guidelines and the actual process may vary depending on your specific dishwasher model. It is always recommended to refer to the manufacturer's manual for specific instructions and troubleshooting tips.
need model number but most Teka models have integrated controls and a compressor system that is shared between freezer and fridge. so it looks like you cant isolate one or the other. if you provide your model number then it might be a special case. here is user information on one model Teka. http://www.fridge-manual.com/teka/teka-tki2-325.html
Is electric,gas or steam heated? :)
I'm joking..for a small DW should be electrical heated.
Can be. 1..no power provided to heating element .2..heating element broken--easy to check with one tester
3.connections for that heating element can be rusted or broken
Good luck
buy Finish dishwasher cleaning kit from the super market and follow the instructions on how to use it. The cleaning kit should be run with empty dishwasher.
THis should help clean the pump and drain hose.
It would help if you mention the model number of your dishwasher. It is hard to get an english manual for Teka.
