"Aw, Snap!"
IssueYou may see the "Aw, Snap!" message if a webpage crashes unexpectedly.
SolutionsIf a webpage crashes unexpectedly, you can simply reload the page. If you're seeing the "Aw, Snap!" message for every page you visit, try the solutions below:
Some anti-virus or firewall applications, such as Symantec Endpoint Protection, can prevent Google Chrome from working properly. Test whether such applications on your computer are causing the error by turning them off temporarily. Then try opening Google Chrome again. If you are able to open the browser, you'll need to create an exception in your anti-virus or firewall settings for Google Chrome. Once you've done so, you can then re-enable the applications. Conflicting applications that users have reported include the following:
Spyware Doctor
Comodo firewall
McAfee Enterprise
McAfee Virus Scan
Try disabling your extensions one by one to see if a particular extension is causing the problem.
Click the wrench icon on the browser toolbar.
Select Tools.
Select Extensions.
On the Extensions page, click Disable for the extension you'd like to temporarily remove.
Go back to your list of extensions at any time to re-enable disabled extensions. You may need to refresh the page in order to use extensions you've re-enabled.
If the browser continues to display the "Aw, Snap!" message, your user profile may be corrupted. To create a new user profile, follow these steps:
Exit Chrome.
Find the "Default" folder. It's usually located in the following locations:
Windows
Windows XP: %USERPROFILE%\Local Settings\Application Data\Google\Chrome\User Data\
Windows Vista and Windows 7: %LOCALAPPDATA%\Google\Chrome\User Data\
Mac OS X: ~/Library/Application Support/Google/Chrome/Default
This a virus! If you don't have important files better to revert it back to factory settings. When the system restore option is still accessible you can try this as a quickfix
If you're a computer savvy person try deleting these files and entries, else call IBM Thinkpad software support:
%UserProfile%\Application Data\hotfix.exe
%UserProfile%\Application Data\thinkpoint.exe
Remove the following associated registry entries:
HKEY_CURRENT_USER\Software\PAV
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "thinkpoint"
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Winlogon "Shell" = "%Documents and Settings%\[UserName]\Application Data\hotfix.exe"
You can try to disable this service by following the below steps: Step 1: Open your computer's Control Panel by selecting "Start" > "Control Panel" from your computer's Start menu. Step 2: Choose the "System and Maintenance" > "Problem Reports" menu option from the Control Panel menu. Step 3: Select "Change Settings" > "Advanced Settings" from the Problem Reports program menu and turn off the automatic problem reporting feature in Windows. Step 4: Exit the Problem Reporting application by selecting "File" > "Exit" from the File menu. Werfault.exe will now only run on your computer in the event of a catastrophic application problem.
If disabling the application does not work, you should keep in mind that many malware programs can show up on your system as seemingly legitimate files by using file names that are very similar to those of legitimate files. Whenever you are in doubt about a particular file, always scan your system for viruses.
Orkut is one of the product of Google. It is better in Chrome. the "err_connection_reset" comes under delay of page accessing so check it out your browsing speed. and check any "spy look" on your system while accessing the orkut [social web]. Make sure of fine availability of processor time, browsing speed along with chrome settings.. if you got the same, then notify the error message with out error.have fine
hi. its purely a virus problem that prompts u from performing some actions in ur system. visit filehippo.com website. download AVG anti virus latest version scan ur computer. the problem wil get solved.
