My Magic Bullet (given to me as a Christmas gift) has broken. I need to know how to get replacement parts or repairs. The mechanism in the base that is clear plastic with 4 "wings" and connects and turns the chopper in the cups has broken. One of the "wings" broke off. How do I get it fixed?
Thanks, Cindy Richardson
Take a look on amazon here Amazon com magic bullet blender parts. I hope it was helpful. enjoy
I had the same problem,broken plastic drive gear.
solution ; sacrifice one of the blender choppers bases you use the least (usually the flat cutter)
hold the cutter blade with pliers or in a vice if you can and unscrew the rubber gear off the shaft in a clockwise direction -- CLOCKWISE--DIRECTION-- easy huh.
Now insert screwdriver to suit,(coss,phillips or flat blade type) into centre hole in underside base of power head drive unit. Hold unit firmly and now unscrew broken gear or brass centre piece left behind CLOCKWISE again off spindle.
Finally screw rubber gear back onto motor spindle in ANTI clockwise direction. DO NOT over tighten. Rotation of motor and drag caused by blending action tightens assembly with use.
Done. for pics follow this link
http://www.ehow.com/how_5137984_repair-magic-bullet-blender.html
thanks so much for the tip, it really worked. today when the plastic drive gear of my beloved mixer broke i lost hope....but after implementing your tip the problem resolved, i am back with my favorite mixer less one blade...thanks once again.
Absolutely amazing. Took less than 5 minutes and I am back in business. Thanks!
i have replacement base gears available,if this is what you need please submit your orders to [email protected]
Works like a charm. WOW, Ten minutes to switch them out and I'm back to making smoothies again, THANKS A BILLION
Thanks so much. I bought a used one at a garage sale. The first time I used it it broke like everyone elses in the base. For the girls out there. It was a little tricky to hold both pieces at the same time the gear came off the flat blade base quite easy, but I had used vice grips when it came to taking off the brass centre piece. My screw in the motor base was a blade type and I had to make sure the blade size was right or you will strip the scew of the spindle. and then you have nothing that works. Thanks again the internet can be great!
Worked great. Thanks for the tip!!
the link is outdated, and my model does not have the center hole that attatches to a tool such as the screwdriver. I used your tip to learn which way to turn the blades, but if others also have this problem, you can remove the plastic "star" without tools by putting both the cross and flat blades facing each other and turning the bottom pieces. (I had an extra set of hands to help). The brass centre piece in the base however did not come off for me to install the rubber piece. This must have been upgraded to avoid "homemade fixing". If anyone can help, let me know!
AWESUM!!! 5min job and it's back up and working!! Almost threw it out due to frustration of not getting a part for it. These should *** with a spare! Thank you so much for your tip!!!! You beauty!!
please search my video on you tube under fix or repair magic bullet
excelllleeennnt back to work... :-)))
I purchased my magic bullet in April of 2013 and I love it , but the bottom of my chopper blades stripped off and I don't know how long my warranty is for. Does anyone know how long warranty is?/////////////////////////////////////////////
Super simple and effective. Could not "lock" the motor from below but was able to use a flat head screw driver to hold and turn the screw that connects to the brass impeller. Works like a charm.
So, rather than pay for an entire new motor and wait for two weeks for them to get it to me, I just made a new gear/broken thing. I crazy glued the old piece back together again and used it to make a plaster mold...like the way people do with their kid's hands. Then I filled the mold with JB Weld and let it dry. After that, I drilled a hole in the new JB weld gear so that it would fit over the metal part in the bullet(that actually spins).
Glued it on (with more jb weld) and the thing has been making my smoothies and grinding my coffee with no more issues.
Sounds complicated, but it wasn't too bad. Funny thing is, the new piece is probably heaps stronger than the cheap plastic thing that broke in the first place.
Do it yourself, or e-mail me: [email protected]
I'm tired of made-to-break products and could make anyone else one of these things for around 10 bucks!
I am so impressed and thankful for people like you. thank you for your commitment to thumbing your nose at made-to-break products and keeping the bullet out of the land fill
My best,
joey
can i get any other gasket to work in my bullett or i have to order from the company what is cheaper & easier bugger i never got any extra 1s or a booklet
The same thing happen to me. I checked on e-Bay but to buy new base I had to pay more then $30.
I checked the www.buythebullet.com and contacted the Homeland Housewares on 1-866-446-6352 and they told me that the only thing I can do is to buy new power base and they will ship it to me for $19.98 (S&H included). Waiting for it now.
I had same thing happen to me, except that mine was 3 yrs. old. (If Cindy's was received xmas '08, it is in warranty.) But for those whose are not, I contacted the manufacturer and was told that there was no replacement part, (the clear plastic center disc on top of base,) but they offered a new base for $19.99, including shipping. I gladly purchased it, because I had searched for one on ebay, and the only 2 displayed were used, and much more than this; $35-40.00, with shipping. Hope this helps.
I have an isagenics blender. I have been told they are the same. I tried swapping the chopper base with the blender base, they are different size screws. The blender base requires a bigger nut on the gear. Do you know what size your replacement parts are?
Andy
I had a problem where the rubber "teeth" at the bottom of the blade just sheered off. All I did was brace the blade with a pair of pliers and unscrew the rubber part (clockwise! opposite of what you're used to!) and replace it with the other one. I never used the other blade anyway! I also read that you can sacrifice one of the blades and use the rubber part in place of the plastic part on the base...
Yes, My Magic bullet cross blade has plastic worn off at the base and I am able to buy from Magic bullet Customer service at 1-866-446-6352 and they said that I can buy only the blades for about $ 8.98 each.
Hope this helps
Good luck with your bullet.
They work with two wings, even with only one wing it works, just be sure to put one wing in front of the magic bullet logo (the power base)
I need that little black plastic unit that fits on the brass hub in the motor. Without it, I cannot spin the blades. Is that the base gear you speak about? If so, please contact me:
[email protected], or 814-723-1529.
Thanks, Larry Neal
Spoke with Homeland Housewares, the maker of the MB, on Sept 17, 2010 and they said it is not possible to buy just that clear plastic piece; you need to buy the complete base assembly for $19.95.
My Magic blender will not run--I tried contacting the HoomeHousewares co. to no avail--i paid extra money for insurnce on the product--no answere to phone calls to homeHouswares
sure miss the blennder
I carefully took my blender apart. Cleaned it with a tooth brush and reasembled. I paid paticular attention to the electrical connections with cleaning. Some items you blend will lose a drop here and there and it builds up or shorts the connection. It runs great. I did it again when it failed again (3 months of use) and it started up again without a problem. The gear shattered the other day. It just slips on. That's all I need is a gear. Simple and inexpensive. I'm stil searching.
The blender attachment is stuck to to the jar/cup; I have tried hot water, oil, the old tupperware bottle opener sheet and my husband, and still cannot get the two to separate - any suggestions?
To get the blender unstuck from the jar, push Down on the jar really hard and twist in the OFF direction. I had to put my blender on the floor to get enough force to push Down on the jar hard enough, and then I had to twist as hard as I could in the OFF direrction to get the jar off.
I had the same problem! I had to run the black blender base under extremely hot water, almost boiling, for about 1 or 2 minutes while letting the cup stay cold. Then it came apart easily. The key is getting the base to expand with hot water while keeping the cup contacted from being cool.
Https://www.youtube.com/watch?v=0uF2_bALm_o
GO TO BLENDERGEARS.COM, THEY HAVE THE PART YOU NEED
The base of the magic bullet was broken, the clear part of the base when I put the wing broke
Guys you can but new replacement parts through Ebay in the us or Amason but won't ship to Australia. Black rubber bace for under the cups was $9 & the drive in the power base plastic was about $18,
Hope this helps
I had the same problem and found a solution online. I just completed the repair myself, with a little help from my husband tools. I removed the black rotating piece from the blade that I used less and attached it to the base (after making a minor change to the base so that it can screw back on.) I will post the link. Remember that to remove the pieces you will be turning it the opposite direction as you usually would to unscrew something. (Typically righty tighty, lefty losey but you will want to turn it right to loosen it this time.)
http://designerjones.com/2005/10/28/the-magic-bullet-review/
Good luck,
Susan
I bet that at least 1 of the 3 tiny plastic knobs on the outside of your cups has broken off. That happened to me, and that meant the motor wouldn't engage, which was a mystery until I figured out why. I was left with only one cup that worked, until yesterday, until that one broke too! Seems like the cost of replacement cups are more than replacing the entire system! Sigh!
Buy the new power base here http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160783205909
Buy the cross blade here
http://www.amazon.com/gp/product/B002YEJYSO/ref=sc_pgp__m_A1KB97A5SK5WKE_1?ie=UTF8&m=A1KB97A5SK5WKE&n=&s=&v=glance
Same problem. This seems to be the achilles heel of the magic bullet. That's the problem with plastic parts. Let's all go on strike till bullet fixes their folley.
Boy...the same palstic coupler broke for me too...got this tip:
paid a mechanic Rs. 10/- to get the rubber coupler from one of my existing blade...voila..it is back & working great.
On ebay india..we get two blades for 299/- only...will get them as well...nice tool this kity.
My magic bullet works fine, the problem is i don't have attachments and blades for using its chopper and grinder...is anyone willing to give away those...i am highly interested in taking them...please e-mail me at [email protected]
I have the same problem, (except the part is black in my Magic Bullet.) I know it's the same part because you described it perfectly. The part broke into three pieces. I am going to try contacting the Magic Bullet company for parts.
Same thing happened to mine. The mechanism in the base that is dark plastic with 4 "wings" and connects and turns the chopper in the cups has broken. Two of the "wings" have broken off. It seems a shame to replace the whole bullet base just because this small plastic part broke. Can the dark plastic be replaced? I've looked on eBay for parts, but there are no replacement parts for that. How to repair?
Same thing happened to me - my ring broke into two. I contacted Customer Service and hopefully they'll write or call.
My Magic Bullet has broken. I need to know how to get replacement parts or repairs. The mechanism in the base that is clear plastic with 4 "wings" and connects and turns the chopper in the cups has broken. One of the "wings" broke off. How do I get it fixed?
Alejandro
My Magic Bullet has broken. I need to know how to get replacement parts or repairs. The mechanism in the base that is clear plastic with 4 "wings" and connects and turns the chopper in the cups has broken. One of the "wings" broke off. How do I get it fixed? please email me at: [email protected] with the solution.
Thak you
Alejandro
the part in the base that spins the blades broke off
the part of my magic bullet in the base that spins the blades broke completely off
 I need to know how to get replacement parts of the Magic Bullet blender. The mechanism in the base that is clear plastic with 4 "wings" and connects and turns the chopper in the cups has broken.Â
SAME
In my MAGIC BULLET the same rotating part with 4 wings on the base broke, do I have to throw it away?
Very similar problem, but it actually broke into three pieces - I tried to super glue it back together, but now it doesn't fit back in anymore =(
Plastic gear also broke into four pieces.
exact same problem. I'm lost as what to do, and no one seems to have answers.
One of the wings have broken off and a crack started across the whole piece. I tried to super glue it so it would not crack any further and that worked for about 6 more months. But finally the crack must have gotten bigger as the piece is no longer turning the blades but I can hear the engine whine.
My Magic Bullet has broken. I need to know how to get replacement parts or repairs. The mechanism in the base that is clear plastic with 4 "wings" and connects and turns the chopper in the cups has broken.Please advise asap how to get this repaired?
Same exact problem...the clear plastic piece that the rubber portion of the blender blade's unit has a triangular piece broken off of it. I have written to Homeland Housewares to ask if I can order a piece and if so, would it come with instructions as to how to replace it... I just did that today. I will be EXTREMELY disappointed if I can't get the piece. I have extensively researched this on the web and my hopes aren't high. It doesn't look like they repair/replace them without the extended warranty having been purchased. Without it I am nothing! Ok, that's a little harsh, but I use the little bugger almost every day and I love it. I don't have the money for another right now...
i have a jack lananne power chopper and the plastic becker has wings to push down the start choper one of these have broken off i need to buy new plastic beckers the large one and the small one please contact me on [email protected]
buy the plastic gear from amazon
http://www.amazon.com/gp/product/B0081L9...
We have the same problem. We have had our Magic Bullet for over five years and use it daily. Now the rubber piece that holds the blades on is torn and doesn't grasp onto the gear. Wondering if maybe it would be better to just purchase a whole new Bullet.
Could be a great appliance if they didn't make it so fragile & cheap, with only a 30 day return policy. Conclusion: plastic landfill; better to splurge for a vitamix & the extra 32oz. blade/cannister from Costco etc. during a road show, or elsewhere on sale.
I open up a base and removed the wiring and the power cable. now don't know which wire goes to which side of the power cable. Red on bigger side of the pin or white. pls let me know...thanks
After 4yrs the same gear broke on my magic bullet so i found the gear part on amazon for 8.50 + shipping
I'm on the phone with them (MB) now and they say that piece is NOT available for purchase, you have to replace the whole MB motor unit. This is NUTS!!!! That a $.02 piece of plastic forces you to purchase the a $20 motor. I'm so upset and want to post negative reports to the world of this insanity and waste of a perfectly good motor system for a stupid piece of plastic. When I spoke the person they too were surprised of this too.
Hey, My Magic bullet keeps on running on for seconds even after I release it from lock and/or pulse. Any way to fix this?
Mine broke too -- the same part, after only ONE MONTH of careful usage. I'm very disappointed.
