SOURCE: while running on treadmill, the belt seems to
Probably just needs lubricant, like in the kit at Treadmill Accessory Kit
SOURCE: once treadmill is turned on it starts then a
It sounds like you have a reed switch malfunction. The reed switch is located next to the front drive roller at the drive pully under the motor hood. It is the little black wire with the pick up on the end. It need to be about an 1/8th of an inch away from the magnet that is mounted in the pully. If it looks lined up and is not twisted, check the other end. It is plugged into the controller on the other side. If all looks fine, you just might nee to get another one.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
