This is the link to the DIY website for the 1997 Geo Tracker http://www.automotix.net/autorepair/diy/1997-geo-tracker-repair.html
You can get a wiring diagram off this site or got to you local auto supply house such as NAPA and buy a Repair manual for about 25.00.
Hope this helps you out and please rate/vote or place a testimonial on my advice.
Wicked Angel
Testimonial: "I appreciate the advice, as this will help me to resolve any problems that I encounter with my Tracker. Have a great day!"
SOURCE: 91 geo tracker Wiring Harness
try www.autozone.com you will need to register (it's free and they don't send you junk e-mail). Go the the repair info section. If it is not on there, try your local library for a Hayes or Chilton repair manual
SOURCE: looking for diagram of parts in front axle housing
Go to the dealer they will usualy print one for free
SOURCE: I need the wiring diagram for a 96 Geo Tracker
1996 Geo Tracker Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White
Car Radio Accessory Switched 12v+ Wire: White/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Yellow
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): White/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Light Green/Black
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Gray/Black
SOURCE: 1993 geo tracker fuel injector
ecm does control but is also based on input from the Throttle position senser. unplug the TPS and try again. Also make sure the ECM and engine grounds are good
SOURCE: looking for timing belt diagram on 97 Geo Tracker
Click on the following free, direct Link. It has the Timing Belt Diagrams, including Marks and Instructional Diagrams.
Let me know if this helped...
http://www.2carpros.com/car_repair_information/year/1997/make/geo/model/tracker/1997_geo_tracker_timing_belt_diagram_marks.htm
