Try this:
1. Enter a computer that can link to Internet. Download a Windows password recovery tool (I recommend Windows Password Recovery Tool 3.0 ) and install it on that computer. Note that: there is a ISO image file. Burn the file into a CD or a USB flash drive.
2. Eject the created CD/USB and insert it into the locked computer.
3. Reboot the locked computer (it's necessary for you to change your computer's Setup to make it boot from CD drive or USB drive) and then followed the process of instructions. Just a few steps, the old password was removed.
4. Now login Windows and set a new password.
Im looking for help password i forgort,
Try SmartKey Windows Password Recovery Professional, it is a good password recovery tool to recover lost password for you.
Now it has promotion until Jan 15th,2013
http://www.recoverlostpassword.com/promotion/christmas.html
Have you forgot laptop password on ASUS?
Now, we'd commend you a professional ASUS password reset software- Windows Password Key as your reference.
Time: 5 Minute!
Recommend: +++++
As an easy method to reset laptop password on ASUS, there are only four steps as follow:
Step1: Download Windows Password Key ( http://www.lostwindowspassword.com) and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your hp PC by the bootable burned USB in minutes.
Step4: Remove the forgot ASUS password on the operation interface and logon PC without password.
In my opinion, using Anmosoft Windows Password Reset Software or free Ophcrack is the best method to reset Windows password.
Anmosoft Windows Password Reset Software is such software that you can reset forgotten Windows password for Windows 7/XP/Vista by burned CD/DVD/USB. It is professionally designed to reset lost password with less time-consuming and 100% recovery guaranteed. Also it can reset windows password for Windows Server 2008/2003/2000.
If you want to get more information about Ophcrack, please login Ophcrack Official Website.
I have ever forgot my Windows password, but I then bypass Windows 7 password using Password Recovery Bundle.
If you forgot the Windows login password and want to recover or reset Windows password, there is two methods to help you reset the Windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows password.
Method 2: Using Anmosoft Windows Password Reset to recover or reset Windows password, it support Windows all Windows versions like Windows 7, Vista, XP, 2000 and Windows Server 2008(R2), 2003(R2), 2000, etc
Anmosoft Windows password reset software recover or reset Windows password by four steps:
Step1: Download Anmosoft Windows Password Reset V8.0 and install it.(Download from here: http://www.resetwindowspassword.com).
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
which password you lost Administrator or User ? If you lost administrator password then you can reset it with the use of user account and vice versa. if you lost both password then password recovery tool is only option.
As you forgot Windows password, you can use a reset Windows password tool - Windows Password Breaker to help you remove the forgotten password and get back in your laptop.
Password for what?
Remove/reset lost Windows password you can use Windows Password Rescuer, it can reset/remove Windows 7/vista/xp/2008/2003/2000 password instantly.
I highly recommend [Daos Password Recovery Bundle 2012].[Daos Password Recovery Bundle 2012] is an all-in-one password recovery software, which recover password for Windows, Excel, Word, Access, PowerPoint, Outlook, RAR/WinRAR, ZIP/WinZIP, PDF etc. Over 70+ types of passwords can be recovered instantly.
Yesterday, I did not remember my Windows logon passwords. Finally, my workmate Randy recommend Windows Password Reset 9.0. This beneficial tool successfully help me access to Windows. You can Search Windows Password Reset 9.0 or have a look at their official website: http://www.reset-windows-password.com/reset-windows-7-password.html
If you lost windows password, you can go into safe mode (F8 when booting up) to recover windows password, but you forgot administrator password, that way doesn't work. you must use software to recover administrator password. This method is very easy. You can go to this site http://www.reset-windows-password.com/how-to-reset-windows-password.html
If you forgot your windows password you can reset it with windows password reset tools. I think this message can help you http://www.passwordseeker.com/howtouse.html
If you forgot your windows xp password, you can download a software at http://www.reset-windows-password.com Last week I lost my windows xp password. At last, I found it and reset my windows password successfully.
If you lost windows login password, you could get into safe mode (F8 when booting up) to remove windows password when you forgot user account password, but when you forgot admin password, there's no way to change it, you should use tool to recover administrator password. Last week, I forgot my Windows administrator password. In the end, I successfully remove my Windows password by using Windows Password Seeker. It's worth a try.
This is only possible if you are using Windows XP. If your operating system is windows Xp, follow the steps below,
That's all. In other words, the user name and password is administrator.
But
in the case of windows Vista, you will have to re-run windows operating
system, because vista security is very tight and it is difficult to break
into its password.
Take care.
Have you contacted ASUS support web site for instructions?
yes
