SOURCE: Washer makes loud thumping after finished spin cycle
Remove washer cabinet (easy to remove)and check that "base pads" (there are 3 pads, located under the main tub)are not worn. In case they are worn (even one of them), you should replce them all. Good luck !!
SOURCE: FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
SOURCE: whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
SOURCE: whirlpool washing machine won`t spin or pump out
1-check the drain hose maybe cloged 2-check the drain filter maybe filed with materials 3- check no spin mode maybe you selected thank you
SOURCE: My whirlpool duet keeps displaying F35 and will
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed, there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this
problem you have to take the bottom front panel apart and then clean the drain
filter pump assembly completely, make sure the washer is unplugged before
working on it. Please get back to me if you have any other questions.
Kevin
