Question about Proton MS-42 LCD TV
My 4 year old HDTV picture no longer coming on- there is just white snow. originally thought it was connection to unit but checked that and still no picture .Could my video card have gone out??? Any help appreciated. Michelle(mother of little 4 y/o who is missing Diego/Dora-please help.
    Top Expert:
  • Proton Master
  • 64,245 Answers
TRY CHANGING THE INPUT
Posted on Dec 02, 2018
SOURCE:
My 6 year old 32inch envision tv no longer has picture or sound anymore even after its properly connected to cable
Based on the brand parts may not be available and six years is better than average life for this type of set.
Dec 12, 2012 | AOC Envision L32W461 32 in. LCD HDTV
Philips 32 Ambilight PF 9986 TV Picture Problems - Fuzzy & Loss of Picture
What are you using for signal to the set? (Box?) and how are you connected? (HDMI?)
If HDMI try going Component
It may be the box/HDMI hook up causing the problem.
Mar 15, 2012 | Televison & Video
I have a three and a half year old Pioneer 50 inch Plasma TV. I have been very happy with the picture till now. However this week the picture appears a little dull. White color appear like off white. I...
Age... Pure and simple. The backlighting and the display panel start to fail and the white is the first you start to notice, its probably not going to last a lot longer. Plasma tv's are nearly impossible to repair now days due to parts availability and service information, plasma tv's just went the way of the dodo bird, its all LCD now days. Ever time i get a plasma tv in for repair its generally headed for the recycling dumpster.
Dec 31, 2017 | Pioneer PDP-5080HD 50 in. Plasma HDTV
My Wii was connected to a normal-old TV and was in black and white. Okay, so I then tried to see if connecting it as a HDTV version would work (in the settings)....well, then everything turned into...
What happened when you selected HDTV is that you activated the output to the HDMI output. This turned off the regular connection. Press the power and reset button simultaneously when turning on the unit to return it to the factory default settings. Otherwise, you'll have to connect it to a HDTV with the optional cable to connect it (you'll have to purchase that as well) to go in and change the settings back.
Feb 06, 2010 | Nintendo Wii Console
White appears pink
I contacted Praktica Support and it seems that the camera is faulty and needs to be replaced. It was the white balance faulty.
Jan 06, 2010 | Praktica DCZ 5.4 Digital Camera
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
No picture, vertial lines w/many colors, snow
lg plasma tv is not for a novice to play with. the three main circuit boards are control. y and z sustain and they are not repairable
find a shop that can replace the defective one for you.
May 17, 2008 | LG 42PX5D 42 in. Plasma HDTV
RCA F36450 TV is intermittently snowy
Your tuner assembly has a bad connection inside of itself, or there is a bad connection around the tuner assy. if this is an ATC113 chassis Good Luck
Mar 21, 2007 | RCA F36450 36" TV
Snowy picture and Yellowy Whites
Make sure the TV setting is set to or . A power surge may have reset your ?cable-ready? TV. Check the cable setting on your TV and make sure it is set to or . If a VCR is connected: * The VCR needs to be on channel 4. * VCR may not be ?fine-tuned? to channel 4. Locate and adjust the fine-tuning mechanism until the picture comes in clearly. * The <3/4> switch may be in the wrong position. Locate the switch on the back of the VCR and set it to <4>. If a converter is connected: * Make sure the TV is on channel 4. * TV may not be ?fine-tuned? to channel Locate and adjust the fine-tuning mechanism until the picture comes in clearly. * Determine if the converter is bad. Locate the cable wire coming in to the room and connect it directly to the back of the TV. If the picture is clear, your converter needs to be exchanged. Give us a call or stop by your local office and we?ll switch out your equipment. Check the fine-tuning of your TV
Jan 11, 2006 | Fujitsu Plasmavision P42VCA30EH 42 in....
Proton MS-42 LCD TV Logo
Top Proton Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
