Why Disk Fragments a problem?
Any storage action on the magnetic disk like creating, deleting, moving, updating and copying files will lead to fragmentation and consequent performance loss. As time goes by, this accumulation of fragments on your hard disk becomes bigger and bigger. As the hard disk reads and merges these separate fragments every time you open a file, they will eventually cause problems such as system slowdowns, PC crashes, slow startup and shutdown, and will even shorten the life span of your hard drive. That is why defragmentation is so important for your entire computer system.
Advanced Defrag – The better and easier defrag solution!
You may find various defrag programs in the market, they may look the same, but many of them lack of ability to
effectively defrag all the MFT (Master File Table), they will automatically skip certain system files with extensions
such as DLL, INI, COM etc during the defragment thus left remnant fragments after each defragment action, it can
also easily get halted while defragging which is very user-unfriendly.
Advanced Defrag rectified all the cons above from these defragmenters, and the efficiency is even better. Its advanced
defragment arithmetic not only enables you to fast defrag, but also defrag completely and thoroughly. If you would
like to give your PC hard disk a completely care and experience the most efficient defrag technology, Advanced
Defrag is the perfect choice for you.
How it works?
Your hard disk controls a magnetic head which searches the areas where the parts of the required file are located,
reads the data and transfers these fragments to the disk cache or EMS memory. The time this takes is called the
average seek time. The average seek time of most hard drives is less than 9.5 millisecond. The Advanced Defrag
program is able to collect the various fragments of each file and store them very quickly into contiguous space on
the hard disk which greatly reduces the seek time of the magnetic head. Better file reading and writing speed is
provided as a result. It does make a difference if you have got used to work and play with a fast and smooth system.
It also helps to prevent premature hard drive problems and retrieve the data in the event of a drive crash.
Download Advanced Defra :
http://www.versionhunter.com/windows/System/System_Miscellaneous/advanced-defrag.html
