? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 30
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
2 blinks means - over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
B+ over current protection (OCP), unit goes to the standby mode then
circuits.
There is a error in TV.Count how many times blinking the red light.
Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
One blink - not used for the self-diagnosis
Two blinks
- B+ over current protection (OCP), unit goes to the standby mode then
of the circuits.
Three blinks - B+
over voltage protection (OVP), unit goes to the standby mode then
displays the 3 blink fault. This is also a problem in the power supply
circuit, check T603 and R672.
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Five blinks
- AKB circuit (automatic kine bias), the timer/standby indicator blinks
for about 30 seconds then goes to the self-diagnosis function.
Something is wrong with the video. Check video out, Q705, 732, 761 and
other components on the C board, also check Q218, 219, 220 on the A
board. In addition, unit could be in IK blanking, try turning up screen
slightly.
Six blinks - No Horizontal
(H STOP), no raster, goes to the blinking self-diagnosis function
immediately. Check C515 & 516 and the jungle IC, IC206.
Seven blinks
- High voltage shutdown. The high voltage has exceeded 33k and the unit
goes immediately into safety shutdown. Check power supply regulation
and horizontal circuits.
Eight
GA_googleFillSlot("TL-IMU-Article");
blinks
- Problem with the audio (AUDIO), unit goes to standby and blinks the
self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some
projection models of Sony TV sets, this code means that T8005 (flyback
transformer), or the associative components in the high voltage
circuits are defective on the D board.
GA_googleCreateDomIframe('google_ads_div_TL-IMU-Article' ,'TL-IMU-Article');
Nine blinks
- Replace D 6116 and D 6301 on the "G" board, do not resolder as this
will fix the problem temporary. Or Panel Module Error or Thermal Error.
If it is intermittent 9 blinks, meaning sometimes the TV comes on and
other times you get flashing, then change the switching regulator on
the "G" board or check connections. Make sure the regulator is -12 or
-13 (negitive).
Ten blinks -
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on
the " D" board. If the transistors are bad, check R8051 and IC8005,
also on the "D" boards
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
