SOURCE: keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
SOURCE: Thermal fuse blew again.
One thing to check would be the blower. I'm not familiar with your model dryer, so I can't tell you how to get access to it. But if the blower is loose on its motor shaft, it won't move enough air and this can lead to tripping the high limit or thermal fuse failure. You may find a mounting clamp has come off, or the blower wheel may need to be replaced.
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
SOURCE: whirlpool GEW9200L not heating up, i have replaced
not being sarcastic, but, your sure you have 240 volts present at the unit? then check door switch heat section control of switch may be bad
