I've had a similar problem. My solution was to install a third party app, which can twick the settings of the audio. You can find lots of apps like this one: How to fix all Audio Speaker Microphone problems in Android Sound About .
SOURCE: My HTC Touch suddenly turn off, and Is hard to start it again.
the solution to the problem is explained in detail here
http://mastermindinaction.blogspot.com/
SOURCE: downloading photos from G1 phone to laptop
At the top of your phone display you will see a USB icon. Click on the top of the screen and mount the memory card. Your computer will recognize your memory card as a disk drive.
Click on my computer and select the letter for the memory card. Look for the photo folder.
T-Mobile is doing an over the air upgrade to fix some syncing problems this week.
Contact 611 from your cell phone and select G1 support for more information.
SOURCE: My G1 can't power on :<
sounds like the red buttons have stopped working. you can attempt to reset the phone, if that fails either the button will need to be replaced, or you can contact T-mobile for a replacement given it is still under warrenty.
to reset the phone, try this:
with it OFF press the HOUSE and the POWER buttons until the phone powers up with a triangle and a yellow '!'inside. slide open the screen and press 'ALT' and 'W' at the same time. the phone should boot up as normal. if that fails, call t-mobile 1800-937-8997 for a replacement.
SOURCE: speaker on g1 phone stopped working
open your phone and clean the contacts between the speaker and the board.... that is the common fault for cellphone speakers.
SOURCE: HTC G1 dead, can't power on, factory reset/soft reset not working
Well try to get your hands on either a second G1 phone or a multimeter to rule out a battery issue. If you take a charged battery from another G1 and it still doesn't turn on you will have a logic board issue. With a multimeter you can measure the battery directly, if the phones doesn't turn on if the voltage is over 3.7V, you'll have a logic board issue as well. Within one year T-Mobile should give you a replacement. If you can't get a replacement under warranty there is both an T-Mobile G1 Repair Guide and a third party T-Mobile G1 Repair Service, If you try a self-repair make sure you feel comfortable with opening devices that are not meant to be user serviceable.
