SOURCE: replacing light tunnel (instructions)
Hi, if you did not get help until now, i can send you step by step instructions and photos how to do it. I did several of these and it is not a big deal.But you will have to take apart a very sensitive optical device and if you are not confident that you can do it do not start this.bp67-00291a is the part number for the light tunnel.post a message here if you need that file with instructions
SOURCE: samsung hlp4663wx/xaa (after replacing the color wheel)shadowing
If the color wheel you replaced was the BP96-00674A, it would have come with the proper cca adjustments for that particular wheel. You must enter the service menu and reset the cca's for proper color.
SOURCE: DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
SOURCE: I have a 56" DLP Samsung (HLR5668W) Right side goes solid black
The color wheels will never fix an issue like that. The only things that will cause that issue is a bad DMD board which is part of the light engine or the digital board which is not. Freak Squad need to replace the digital board.
SOURCE: My dlp tv has a shadow about 6'' wide and full ht of tv
Hello: The problem is that a small mirror on the light tunnel has fell off causing a shadow in the picture,. In the past the only way to repair this problem was to replace the entire Optics Engine. But Samsung decided it was replacing entirely to many light engines so they decided to allow and train technicians on how to do it. It involves removing the color wheel and behind it is the light tunnel where light from the lamp shines on to a maybe 1 1/4 inch small block with three mirrors on all sides, your problem is that one of these mirrors has come loose from its side, causing a shadow with the pic still in the background. So if you call a technician to come, if he has'nt had the training from samsung on how to do the procedure then he will want to replace the entire optics engine which is the expensive way of doing it.
So when calling as if they know how to replace light tunnel. There are some adjustments that also needs to be done once it's replaced. To verify what i am saying go to this site to find out more. http://www.avsforum.com/avs-vb/showthread.php?t=758625
Call if you need more info will be glad to help..
[email protected]
Phone: 702-418-1389
