Check here: https://www.wikihow.com/Remove-Motorola-Subsidy-Password-Message
Good Luck
SOURCE: Need Boost SIM card to work in Nextel Motorola Buzz+ ic602 phone.
I called Boost support about the same issue and I was told that that particular phone and any other Ic series phone by motorola will not work with Boost Mobile. There was also a few other phones that will not work. Try calling thier support line and requesting the list of phones that won't work. Good luck.
SOURCE: subsidy lock on my i870 nextel
If you enter wrong password for more then 5 times,it ll ask you to enter the puk number....now call your customer care and
get the puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deleted.
OR if you contact your customer care they will unlock from there.
Hope I`ve helped...
SOURCE: i bought a BOOST clutch, but i have a NEXTEL sim c...
It requires special software... I recommend taking to a local cell phone repair center.
SOURCE: i need subsidy lock special
You cannot use the Boost Sim card after Unlock the Motorola I570 ,also You cannot unlock the Boost Network Locked Mobile,because that is CDMA Network,Only GSM Network Locked Mobile can be Unlocked also after Unlock You can use Only GSM network mobile....To Unlock the GSM network locked Motorola I570 You can get the Unlock code at here
http://www.superunlockcodes.com/motorola-i570/rs12wp9/ and unlock IT.
