I had the same problem - couldn't get the part (plastic coupler between the spline drive shafts). I purchased a waterproof **** Splice (GB-AMT-5126 12-10 gauge -- used for electrical wire splicing -- got it at Home Depot). Clipped off about 3/8" on each end with diagonal cutters and attached it to the shafts. The steel ring in the middle of the **** Splice connector provides good structural support to the connection. Works like a charm. Plus with a pack of 4 connectors, I have 3 in reserve.
I'm guessing, but I think that the Sears tool uses the same flexible coupling. If you go to www.searspartsdirect.com and put in the model 572610031, you can look at the diagram and decide for yourself. I think the part costs $2.57. If it's the right one, I'd order two or three for the future.
Hope this helps.
I would call Dremel direct at 1-800-437-3635 and order them. They also have a tech line, but I would think that they are in a bind when installing and cracking. Look at the bearings to make sure they are not tight or completely locked up. Let me know if I can help further
I'll answer last question first. They might be cracking because they are in a bind and when turned on or inserted on the shaft there is too much pressure. Make sure the shafts are free of any debris from the original coupling, also check the bearings for wear or being so tight that they twist the coupling. Everything should move freely. And second I would recommend calling Dremel direct at 1-800-437-3635 for replacement parts. Hope this helps.
Dave
REFERENCE M/N: 395 - Type 3 - Dremel does not have the parts listing on their site for some reason. I actually have the original I saved from 1988! The part number for the Nylon Coupler is: Illustration Code Number: 5 Description: Flex Coupling Part Number: 529430970
This is all from Drawing (Form) Number:5296074 10-88
