Popping noise
Does the " popping" noise come through the speakers or from the TV chassis ?
If it is coming through the speakers you could have a bad solder joint somewhere in the tuning circuit.
If it is a snapping sound coming from the chassis, then you probably have something arcing in the high voltage circiut. If this is the case then you should have it checked out since this can cause other parts to short shutting down you set completely.
