Open your laptop and clean any dust, remove the inside cmos batery to reset any bios bad settings and restore to default, if none helps then you have a motherboard issue, other thing remove ram and clean the thin connectors with a rubber and reinstall. Tell me if some help.
sounds like that card has become faulty. Many things can make go faulty. If you formatted it in a computer that will make it faulty. Sometimes you can still format it in the camera
B is used to power the reversing valve in heat on a heat pump system. The best way to know which color to connect is to look at the indoor unit to see which one is connected there. It will likely be connected with a wire nut and continue to the outdoor unit. If both blue and black are connected and going outside, you may need to look in the outdoor unit to see which one is finally connected to B.
hi, this is due to a faulty connection of your motherboard. did you recently changed anything in your motherboard like wire connection, RAM etc. check out soon or else it might harm the computer.... regards. bzoy
