Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon D40 - The memory card will not stay in. If I put it in and close the door, it still must not "click in" far enough because the camera won't recognize it. The only way it works is if you open the memory card door and hold the car manually while taking a picture. Any ideas on where/how to get this fixed?
    Top Expert:
  • Nikon Master
  • 8,514 Answers
Hi Jfurbees.
this is all i could think off just to help you out in till you can get it fixed.
I don't have a permanent fix, but one thing that works is folding up a small piece of paper and holding it over the memory card while closing the cover so that the cover pushes on the paper which holds the memory card in place automatically when the cover is closed. You just have to experiment to get the folded paper the right size and thickness. Again, its not a fix, but it has worked for me.
I shone a really bright light into the SD slot and sure enough, behind the gold springs at the bottom of the card slot, was a tiny black sliver of plastic that moved slightly when I tipped the camera. About 3mm long.
I removed the camera battery. Then I got a big long sewing needle, and with some very gentle manouvering, so as not to scratch anything inside the camera's SD slot, it fell out just when I was about to give up.
After I'd got the plastic sliver out, I trimmed the splintered edge of the SD card and put it back in
this is not to say it will work for you but give it a try but this will be at your own risk.
Posted on Dec 01, 2017
SOURCE:
  • 6 Answers
SOURCE: Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
Posted on Jun 06, 2008
  • 218 Answers
SOURCE: nikon d40
If the camera is in auto mode, the flash opens anytime the camera feels that it cannot take the picture with only ambient light. You can overcome this by closing the flash once the camera opens it or using a manual mode. In manual mode, the flash opens only if you press the flash button on the left side of the flash housing.
Posted on May 27, 2009
SOURCE: Nikon D60 memory card problem. When i turn my
check your sd card, there's a tiny bar on the side that you can "slide" to unlock...
Posted on Aug 24, 2009
Lardzor
SOURCE: How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
Posted on Sep 13, 2009
Obertelli
  • 3006 Answers
SOURCE: nikon d40 motnior blank while taking picture.
That's entirely correct. Live view cannot work on SLR's whilst the photo is being taken due to the requirement for the mirror and live view sensor to flip out of the way during image capture.
Live view on SLR cameras is a misleading description, it's really a live preview instead.
Posted on Dec 11, 2009
Nikon D40 SD card slot broken
If you feel up to doing the replacement yourself, you may order the part here.
Aug 13, 2012 | Nikon D40 Digital Camera
The problem is Memory card is locked. Slide lock to "Write" position. I have my card in the Write Position only eventhough it is showing the same
Hi there fellow Nikon user, I understand that you're having issues with your memory card. You mentioned that you already put on the unlock/write position but you;re getting the same error message. There's a big possibility that the card's locking mechanism is damaged. I suggest that you try a different memory card to isolate the problem. If inserting the other card doesn't fix the problem, Then most likely it's the card slot itself that is already busted. Have it checked right away by an authorized Nikon technician.
However if the other card was accepted and you're able to write info with it, then we can conclude that the memory that you're having problems with should be replaced.
Hope this help. Cheers!
Apr 11, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40
Try removing the battery and reinstalling it. Also try reformatting the memory card.
Jul 15, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Have put in a memory card, But camera keeps displaying memory card full
Try reformatting the card. Use your camera to do it, not a computer.
Dec 14, 2008 | Cameras
Memory Card Won't Stay In
yes its repairable since the issue is on a camera that is only 5 months old it still falls under warranty. That is as long as your school didn't by a Grey market or "parallel import" Nikon instead of an official camera. You can contact Nikon by calling 1 800 645 6678 24 hours a day 7 days a week. To have them see about repairing the camera free of charge under the warranty. If they cannot repair it free of charge they will tell you how much it will cost for NIKONUSA to fix it and then you can estimate which is more cost effective for the school.
Thanks,
Nate
Sep 23, 2008 | Nikon Coolpix L11 Digital Camera
Memory Card Slot Fault
Please take it immediately to the nearest authorized service center
Aug 24, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
May 26, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
New Camera can't set the language
try this - describes the reset on page 14 or the language menu on page 35 http://www.kenrockwell.com/nikon/d40/users-guide/d40-users-guide.pdf hope this helps:)
Mar 09, 2007 | Nikon D50 Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
153 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
