Upgrade the firmware of your media player. Firmware upgrade will reload the new program for your player and it should work correctly after that.
Unfortunately, all files will be deleted from the player.
Thank you and good luck!
Welcome to Fixya!
Try pressing and holding the power button for 15 secs. If this does not work, look on the bottom of the unit where the USB plugs in to, there should be a small pinhole for a reset button. Press this and after it shuts off, try pressing and holding it for 15 secs.
Thank you!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Try the solution above and then let me know what happens.
This could be a problem of the hard drive connection to the motherboard. If you want to eliminate that possibility, remove the hard drive from the archos. Once removed, connect it to your pc so you can recover the files. This will void the warranty though. If if is still under warranty, I suggest calling Archos .
- Still images: JPEG format or RAW format (preview only)
- Music: MP3 format
- Video: AVCHD, MP4 (AVC) or MPEG1 format (not playable in some cases)
Make sure that you're using the compatible file formats in the USB Drive.
Also check if the USB Drive which you're using is compatible with the TV.
Click here to check the list of compatible devices which Sony recommends,
The accessible file or folder limit in a directory is 1,000 for USB. This limit includes non-supported files or just folders. Files or folders are populated based on their time stamps. Photo, music files or folders exceeding the limit will not be displayed.
Check if the above mentioned criteria meets the requirements.
Thanks for using FixYa.
hi have not yet tried your solution. Today on screen, it says read access error! Can not read from hard drive. What should i do??? Please reply ASAP. Thanks
Hi this is av500 not archos 504. There is no hole for hard reset. How do i hard reset the AV500??? thanks
