Question about Frigidaire Kitchen Ranges
I have the ES530 Control, self-cleaning oven w/bake-n-warm double oven. The stove top and warming oven work fine but the touch controls that control the oven have gone dark and I am unable to use my oven. This range is just 2 years old....any troubleshooting ideas? Thanks! Debbi
SOURCE:
  • 1462 Answers
SOURCE: Fan oven stays warm
is the fan working when oven is staying warm? possible fault if you don't have an earth trip is a short to earth on the neutral side of the element
Posted on Mar 26, 2007
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
fridgetech
  • 473 Answers
SOURCE: frigidiare electric range time bake and self cleaning
Usually f3 means a faulty oven temp. sensor. If you give me the complete model # from the sticker on the oven I can tell you for sure.
Posted on Nov 06, 2007
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
leroyal
  • 2120 Answers
SOURCE: Oven won't heat. No gas smell. Broiler and stove work.
Bad oven control circuit board. Look up on eBay
Posted on Feb 21, 2009
I have a double gas oven, 3 years old. Top oven is not heating, it will broil but not bake. Stove top is working great and bottom oven fine.
This is a tough question because we haven't mention the make and model number you should add that so we can help you better but normally if the top oven is not working properly it may have thermostat problem or it could also be control panel problem can you tell more information especially the make and model
Sometimes you can take it out and it's not working properly and take that oven and put it in self-clean mode and it might fix problems
Mar 27, 2018 | Ovens
My stove top does not respond to the touch
Good Morning Kenneth Kozoway, thank you for your inquiry!
I see that you have explained the stove top on your Electrolux range is not responding to touch and the oven controls are working properly. From what you have described it sounds like a possible issue with your control panel or sensor. I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. If that does not help correct the issue I would recommend having a professional technician come and perform a proper diagnosis for repair. Hope this is helpful. -Matt
Dec 25, 2014 | Electrolux 30" Self-Cleaning Slide-In...
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at www.fixyourboard.com
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
Top and control panel work but oven does nothing less than a year old.
bake%20element2.jpg Bake element Most times it is easy to see a failed oven element. Their will be a hole or a welded mark somewhere on the element where a piece of cheese fell on it and caused a hotspot. You can also check elements with a meter or simply apply some wall current to them using a cheater cord to see if it gets warm. If the element gets warm that means it will work and is not bad. If the element ain't coming on but you have checked it out, of course then that would be the thermostat. HEADS UP: When fooling with the stove always be sure the power is off. Pull out the bottom drawer and most of the time you can unplug the power cord without moving the stove. To make it easier to work on most stoves the oven door can be removed. I set the door at the broil position and gently ease up on the door, remove it, and set it to the side. As far as the oven thermostat goes, they are simple enough to replace but quite expensive. I suggest if you have an electronic oven control then that old extended warranty plan is a winner. Heads Up: One thing you want to remember about fancy electronic controls, never put the stove on self clean! The temperature will cause the delicate electronics to fail. I don't care what anyone says. That stove will get to 900 degrees and adversely affect those controls.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 11, 2009 | Tappan TEF242 Electric Kitchen Range
Have a GE Electric Cook Top oven with digital
Unplug the stove. plug back in and program a short clean cycle. If this does not fix it is eithe the selector switch or the electronic control. Verifying the switch contacts with a meter is the only way to be sure.
Eric
Jun 21, 2009 | Ovens
Electric warming drawer will not heat
Found that there is an electrical connection at the point the main electric enters the back of the stove. There is a connector for the element that was not connected. Now it works!
Feb 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Lower oven won't heat
it must be thermostat in bottom oven
Nov 29, 2007 | Frigidaire PLEB27T9DC Electric Double Oven
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Kitchen Ranges Logo
202 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
