WARNING: DO NOT connect the camera to your computer before installing the software.To
install the software, insert the Logitech camera software CD into your computer's CD-ROM drive. The
Setup screen should appear. If it does not, please perform the following steps:
- Click Start and then Run.
- Type D:Setup.exe and press the Enter key.
- Follow the on-screen instructions.
After the computer reboots, the driver installation for the camera will start. Do not connect the camera until the setup prompts you to connect the camera cable to your computer.
While the driver installation progresses, remove the camera and camera base from the packaging and mount the camera on the camera base.
When prompted, plug the camera into the USB port. You should see the following diagram to let you know where to plug the camera in:
After the installation is complete, the camera should be ready to use.
Thanks
