DeLonghi DEBIGE 2440 Electric Double Oven Logo
frank jones Posted on Jun 20, 2008
DeLonghi ESS601 electric oven
This oven does not get hot!!ive replaced the elemant to no avail and the fan works.But it only slightly warms up,even after 60 minutes?
  • frank jones Dec 22, 2008
    The oven only heats to a lukewarm temperature,even when i turn the temp knob to max?
A
Anonymous
We just moved in to a place that has this oven, if you use the setting with the fan with a circle round it, seems to get hot! Don't know what the other is for though!
Hope it helps!
Pete
A
Anonymous
The problem is that you are trying to cook on defrost mode ie the fan only setting. This just operates the fan without any heat. If you want to use the oven choose the symbol of a fam with a square around it.
Oven getting warm but not hot?
If it is an electric fan assisted oven, and the fan is working o/k, \then you need to fit a new oven element., usually located at rear of oven compartment.
Please rate my solution.
Thanks.
Nov 16, 2009 • Smeg Ovens
2answers
Oven not getting hot but oven fan ligth working
If it is a fan assisted electric ovenn, and the fan is working o/k, then you need to replace the oven element, usually located at rear of oven compartment.
Thanks.
7helpful
3answers
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 • Ovens
DeLonghi Debige 2440 Electric/Gas Double Oven Fan Failure Light
I had the very same problem. I slid the oven out of the wall about 6" or so, unplugged it, plugged it back in. It worked. I'm not sure if I jostled some connection, or if unplugging/repluging it in reset some sort of circuit fault.
Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
Top DeLonghi Ovens Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
