Panasonic CT-27SX12 27" TV Logo
Posted on Nov 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a problem with my Panasonic CT-27SX12 27"
Arthur Tang
Level 3:
  • Master 734 Answers
  • Posted on Nov 18, 2010
Arthur Tang
Master
Level 3:
Answers
734
Questions
0
Helped
158006
Points
2179
On remote you must push the TV button first then the on button to activate or deactivate the TV. Channel or volume on the TV does not need to select anything on remotes.
Panasonic color tv remote model number EUR7613Z70 manual
You will usually find the instructions for using a remote control in the manual for the TV that the remote came with. For the Panasonic EUR7613Z70, this includes the CT-36E33. Panasonic has the manual on the CT-36E33 product page: http://shop.panasonic.com/support-only/CT-36E33.html . The direct link to the manual for the CT-36E33 is currenlty ftp://ftp.panasonic.com/television/om/ct-27e33_mul_om.pdf . The section on the remote starts at page 8.
I hope this helps.
Im trying to program a Panasonic universal remote to clear tunes tv
Search Results
    Need codes for ct-300 clear tunes universal remote - Fixya
    www.fixya.com/.../t17341079-need_codes_ct_300_clear_tunes_universa...
    Mar 26, 2013 - need codes for ct-300 clear tunes universal remote Need codes - Symphonic ST419E TV ... Universal remote code for a panasonic ct-27g14a.
    I have a clear tunes tv and trying to program my RCA universal
    www.fixya.com/support/t25649135-clear_tunes_tv_trying_program_rca
    Apr 16, 2015 - ... a clear tunes tv and trying to program my RCA universal remote to it ... "I need to program an old Panasonic TV with a RCA universal remote ...
    I need the codes to a clear tunes remote for a rca - Fixya
    www.fixya.com/support/t3026751-need_codes_clear_tunes_remote_rca
    Sep 26, 2009 - I need the codes to a clear tunes remote for a rca tv. ... "I need toprogram an old Panasonic TV with a RCA universal remote model RCR311St ...
    Radio Shack panasonic remote control codes clear tunes tv ...
    www.fixya.com > ... > panasonic remote control codes clear tunes tv
    ...remote. the panasonic codefor my radioshack 3-in-one remote is 0250 I need a codefor a VCR Durabrand (DCV603) for the Sony universal remote control or a ...
    Clear tech tv 4 digit code - TV - Other Consumer Electronics
2helpful
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
10helpful
2answers
Comcast Remote Code for Panasonic CT-2707D
panasonic expects a 5 digit code. add a 1 to the codes lists, worked for me. 10250, 10051
Toshiba 15DLV16 lcd/CD combo
mostlikely code is 11256 if ok select switch on the remote is red
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
4helpful
Toshiba ct-90233
Here is a link to your manual:
http://remotes.com/remotes/documents/Toshiba/CT-90233.pdf
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
