Hi, look at this post maybe can solved your problem not all Error E3 means your printer part damage but maybe somethings inside it that makes the printer look likes paper jam,
Canon MP198 Printer Error E3 is because something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things.
Look at the paper sensor there is must be somethings in it. I found this when my printer Canon MP198 got error E3. I found small part of paper in the sensor that makes sensor not function properly. I just remove the paper and the printer working again.
see also
http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html
SOURCE: Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
