SDS drill - the usual process of pulling back the outer sleeve of the SDS chuck should release either the bit or the chuck shaft so it virtually falls out or it can be easily withdrawn by hand - usually...
Some SDS attachments tend towards softness and with extended use can mushroom internally making them difficult to remove and sometimes nearly impossible. Twice I had had to resort to some serious brute force to remove SDS bits after heavy use.
The SDS chuck is an intergral part ot the rotary hammer drill assembly. You can get a standard chuck that has an SDS fitting on it and that will fit into your drill and give you standard drilling capabilities.
Youcan only use standard drill bits with the use of a chuck attachment with the SDS type bayonet. These hammer drills use an SDS type drill bit which just pushes into the fitted chuck and are released by pulling back on the lock mechanism on the chuck.
