I have a problem with my 8gb pen drive, my pc does not add hardware of pen drive ,(its not working). i have checked it on other pc but the result is same. can you please solve this problem.
Okim afraid it sounds like the Pen Drive has died, but without a visual inspection and diagnostic test I cant be 100% sure.Okim afraid it sounds like the Pen Drive has died, but without a visual inspection and diagnostic test I cant be 100% sure.
You can't post conmments that contain an email address.
Click Start, click Run, type compmgmt.msc, and then click OK.
2. click Disk Management. The Disk Management window will appear.
3. On this disk management window, you can see some drives including the portable drive. Right click on your portable drive and click change drive letter and paths.
4. assign a new drive letter which is not used by any of your drives in My Computer.
5. After assigning the new drive letter your pen drive will show in my computer.
Just Check Your Pen drive If It Ok Then Goto System Properties>>Device Manager >>Usb Controller >>Scan Hardware Change!! Check USB Install Or Not If Not THen Install It!!
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
first go to my computer propery then hardware then device manager then go t ousb controller uninstall all usb drivers from there then just right click on any driver then click on scan for hardware changes then it automatic install usb drivers . Connectyour pen drive to usb port check all port. then if its not working check with other usb device is working with usb port?
You need to download and install the drivers for your memory stick. You can do this by going to the manufacturers website (who made the stick) and download the drivers from there.
yes it has a lights,but it does not glow when i inserted in usb socket
i have windows xp service pack2
its good help others by e mail i like this way
