Moen & One Handle Tub & Shower Faucet  Logo
Posted on Nov 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installed new valve but when I screw the handle in I can't shut the water off completely. I can pull and turn the water on but when i push it in, it only turns off part of the way. To shut it off i have to take a screwdrivier and push the screw it the middle of the handle and then as the screw goes in, it shuts off.
Anonymous
Level 3:
Genius:
  • Master 1,015 Answers
  • Posted on Nov 18, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1015
Questions
0
Helped
319876
Points
3041
On most moen single handle valves there is a washer that is supposed to fit over stem on cartridge.This washer has two flat sides to fit over flats on stem. The only other thing I can think of is that your valve face plate is mounted a little to far out and won't let back of handle go all the way closed. I would try tightening the two screws that secure face plate to valve a little and see if that helps. Good luck. Thanks
1helpful
Why won't water turn off?
YOU MUST SHUT OFF WATER FIRST!! Because you need to replace the valve stem washer. Most likely OO washer size, black hard rubber washer is worn out.
Remove the excursion (handle) one or hot and cold. Phillip screw or allen nut back of handle.
You will see a brass valve stem the handle was attached to. Use a crescent wrench and unscrew the stem and pull to remove.
Ar the bottom of the stem you will see the black washer. Remove the screw holding the washer in and replace with new. Reverse steps to install.
Hope this helps, I never know. Mike
Jul 04, 2015 • Home
tip
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
on Dec 14, 2010 • Pool & Spa
Dripping bath faucet circa 1985. Can't ID model but appears to have 2 screws holding front of casting to main body for disassembly . Faceplate is square in shape and black in color HELP!
  • 1 Close the hot and cold water valves in the cabinet beneath the sink to shut the water supply off to the bath faucet.
  • 2 Remove the bath faucet's handle to access the valve cartridge. The faucet handle is removed by first detaching the handle's insert cap using the tip of a screwdriver or utility knife to expose the handle screw. Remove the handle screw with a Phillips screwdriver, then pull the handle off the valve cartridge stem.
  • 3 Loosen and remove the cartridge valve nut with an adjustable wrench. Some faucet models retain the valve cartridge with a snap ring and are removed with snap ring pliers.
  • 4 Pull the old valve cartridge out of the bath faucet base, using pliers.
  • 5 Insert the new replacement valve cartridge into the faucet housing and replace the nut or snap ring removed in Step 3, using an adjustable wrench or snap ring pliers.
  • 6 Reinstall the faucet's handle onto the valve cartridge post, then secure the handle's screw, using a screwdriver.
  • 7 Replace the insert cap into the handle to cover the handle's screw hole.
  • 8 Turn on the hot and cold water valves beneath the sink to restore the water supply.
  • 0helpful
    How do you shut off the water from the valve behind the toilet..i keep turning it but it doesnt appear that the water is turning off??? it just turns and turns??
    It sounds like the valve is stuck and the valve handle is bad. All toy need to do is remove the screw from the valve handle, remove the handle, use a pair of water pump plyers to turn the valve. I would suggest that you replace the valve, to do this shut of the water main. remove the hose that goes to the toilet from the valve, remove the valve, ust Teflon tape and reinstall a new valve, reinstall the hose, Turn on the water main make sure the valve is on, check for leaks. Its really quite an easy job.
    Jun 14, 2011 • Home
    The cold water tap will not completely shut off. With the handle off the cold water slows down but does not shut off. When installed I turned the valve in the direction of instructions before installing...
    Not positive about the model you have, but some faucet handles can be put on when the valve is not in the correct position.
    Try taking the handle back off, turn it slightly clockwise, and re-install it.
    Hopefully this will do the trick.
    Good Luck!
    Jan 23, 2011 • Home
    Usually when I turn the handle on, I have to turn it only to a certain point to start getting hot water. This morning, I had to turn at least two times farther and wait an extremely long time for hot...
    It is probably the regulator/cartridge valve in the handle and is fairly easy to fix yourself.
    Remove the screw cover from the center of the handle (use a small flat screwdriver to pry it off), then remove the handle (phillips head in counterclockwise direction), there is a metal plate behind the handle remove that and tuen you can turn the water off here as well - the middle one is has a cartridge valve and the other two on each side are the water supply shut off - use a flat head screwdriver to turn them clockwise to shut off the water supply.
    There will be a bonnet nut on the center pipe - remove that with an adj. wrench. Pull the valve out (channel lock pliers work well) of the center pipe and insert the new cartridge.
    Reinstall the bonnet nut and turn on the water supply valves on either side, replace the metal plate and faucet handle.
    Good Luck!
    1helpful
    Hard to pull up handle
    Are you asking about faucet handle or pop up drain . If you are referring to faucet handle the easiest thing to try first is to remove center cover from top of handle. It's the one with the moen insignia or name on it. These are usually just a friction fit so use a small blade screwdriver or knife blade to carefully remove cover. There is a screw that holds handle on cartridge. Remove screw and gently remove handle by pulling up. If you have not shut off water supply valves this will open valve and run water. Push down on carteidge stem to shut off water. Use a penetrating oil such as WD-40 and spray around cartridge.Allow a few mins. then pull cartridge stem up and push it back down several times spraying with penetrating fluid several times. You can move stem by gripping with pliers. This should help free cartridge . If this helps you can save on service call. Reinstall handle with screw and center cover. Hope this helps. Thanks
    2helpful
    2answers
    We have a newly installed Delta single-handle shower faucet and cannot figure out HOW to get a warm water mix. No matter where we turn the handle, we get different temperatures of "cold."
    That is a graduated water mixer valve, and it sometimes has a little white water restrictor blocking flow from your hot water port. See if that was left in by removing the handle with all water shut off to the valve and reattach then try again. This can also happen if you have a tankless water heater because pressure controls heat. Typically a Tankless water heater system will require little, to no cold water to your bathtub valve because of the heavy water flow at the tap. Remember, flow equals temperature. Less flow = more heat, more flow = less heat.
    2answers
    No water
    the screw should be a phillips head or allen screw
    3answers
    Top Moen Home Experts
    john h
    Gene Lawson
    deton8 von Splosion
    Are you a Moen Home Expert? Answer questions, earn points and help others
