Sky+ remote code for firstline (hisense?) tv42fs42pro1
Tried sky codes 0836 they dont work, tv is 2/3 years old, also does the remote magic eye work with sky + as there is no way to switch on the tv outlet on the back of the box via the setting menu like u could on the old sky boxes
  • Anonymous Jul 10, 2008
    need the code for a hisense television
Jhj
Posted on Jul 10, 2008
SOURCE:
New remote old tv no sound (sky magic eye)
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Aug 28, 2016 | Televison & Video
Hisense tv
so whats the remote you have there?
Oct 23, 2008 | Hisense TA42P40M 42 in. Plasma Television
What is th? code for a sky remote to work a hisense smart tv
Hi Hans, Unfortunately that remote control will NOT work on a hisense television... The link below is a sky remote control codes site, Scroll down the list and HISENSE isn't on the 3 or 4 digit list. Sorry mate......
Sky Remote Codes
Apr 05, 2016 | Hisense Televison & Video
What is the sky remote code for Logik L24FED13?
0039.0033. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 22, 2014 | Televison & Video
Sky Magic Eye not working over SLX 8 way booster/spliter
have you got it set on second out put on the sky box as number one is just normal. all cables have to be set to second output using a splitter box . so its like this.
arial in booster.
out booster to sky box.
out to tv/etc on first output on sky box.
second out put to spliter linc. ( eg 4 rooms out four way splitter)
each room with sky eye fitted to end of the aerial from number feed from sky box.
with each room with Eye sky can be controlled
also check that RF outlet power supply is set on sky+ or HD in settings menu.
access this.
settings
select ( remote)
type 01 (select on remote)
RF outlets.
RF outlet Power Supply ON
RF channel 25 ( is best for most areas)
Feb 01, 2014 | Televison & Video
Hisense tv code needed
Even though this problem is a year old, I thought that I would share my solution for Remote codes for a Verizon FIOS.
I tried asking Verizon, and Hisense for a code that would work as the published codes did not work to program my Verizon remote. No answer from either.
I accidently discovered that the codes listed for LG worked, in fact the first code listed worked. I surmise that Hisense uses the same codes as LG.
If you are at wit's end then try the LG codes.
By the way. I tried stepping through all codes several times but no success with the Verizon instructions. The fact that the LG codes worked, indicates that the Verizon solution is wrong.
Oct 28, 2009 | Panasonic Televison & Video
My satellite remote control only work at close distance I have canged the batteries I tried it with the other box from bedroom in bedroom they work fine in the sitting room both dont work
Hello Aykuturer,
There are two things that you can try to resolve this problem.
1) most common interferrance for the sky remotes are WII sensors to close to box. or the TV back light is interfearing with it. If this is the case then turn off the WII (if you have one) and try that. If it is the TV back light then you can turn this down or off.
2) If you are still not getting any joy from these then you could always go to EBAY and purchase a Magic Eye / Remote Eye. They are resonably cheap from there.
Once you have got your Magic eye. Connect it into RF OUT 2 at the back of your sky box.
Then with the remote press SERVICES, 4, 0,1, Select then 4 make sure that you turn then power on and then save.
This will sort out any IR problems you are experiencing.
Hope this helps you out, If this does then please leave a thumbs up.
Cheers Little Dish Fitter.
Oct 23, 2009 | Samsung DVD-V4600 DVD Player/VCR
Cannot get my sky guide to respond on my Loewe Articos 32,i think the kids have scrambled the tv remote! Any ideas?
There are several things that can stop your Sky remote from working.
step one:
get a mobile that has a camera on it. point the remote at the camera and press the TV guide button on the remote you should see a little light by looking through your camera. This is because cameras dont like infrared
if you see the light whilest looking from the camera phone then the remote is working.
Step 2:
There can interfearance from devices like WII's or if your television has a back light you can turn this down and see if this is going to make any difference to the sky box.
If it does you know what is casuing the problem.
Step 3:
There may be another solution to your problem. Go onto Ebay and type in there Magic eye. you can get them from Argos but you will be paying 3 times if not more then you can get them off ebay.
once you've got the magic eye. plug this into the back of your sky box into RF OUT 2 this must be in 2 due to it providing 9v to the eye.
on your sky remote press services, 4, 0 1 select. go to Rf setting and turn this option to ON and then go down to save. you should see a little red light on the magic eye come on this is all done.
Now try your remote as normal.
I fit sky and a lot of the HD sky+ boxes have rubbish IR (infrared) so this sorts out a lot of problems.
Hope this helps
Little Dish Fitter
Sep 01, 2009 | Loewe ARC332 32" TV
Sky magic eye not working on hd
I work for Sky as an Engineer.
on your Sky HD remote:
service,
4,
0 1 select
make sure the power is turned ON
now go to the room you can not change the sky channels over with.
you should notice on the magic eye itself should now have a Red led light on it now. you should now be able to change the channel over just remember to press the blue sky button on the remote at the top otherwise this will not operate the sky box.
If not unplug this magic eye and try this directly into RF out 2 to make sure that its not the magic eye that is at fault. If it is working correctly then the light will appear.
Hope this helps
Little dish fitter
Aug 16, 2009 | Televison & Video
Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Feb 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
337 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
