Computers & Internet Logo
Posted on Nov 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove safe mode - Computers & Internet
Kawawa Chitiya
Level 2:
Scholar:
  • Expert 119 Answers
  • Posted on Nov 17, 2010
Kawawa Chitiya
Expert
Level 2:
Scholar:
Answers
119
Questions
0
Helped
29148
Points
361
1. You cannot remove Safe Mode, it comes a boot profile on every computer running Windows, At the start-up menu you can always select the normal boot option to boot normally...
I hope this was the safe mode you were referring to...
1helpful
What is safe mode, located on lower left of screen ?
Safe mode is a diagnostic mode of a computer operating system (OS). It can also refer to a mode of operation by application software. In Windows, safe mode only allows essential system programs and services to start up at boot. Safe mode is intended to help fix most, if not all problems within an operating system. It is also widely used for removing rogue security software.
Start up
SAFE MODE OPTIONS
1. Press the System or Menu Button in the lower left corner and navigate to Manage apps.
2. Find the most recent app you installed.
3. Force close it.
4. Disable it if possible.
5. Remove this app.
6. Reboot the boot to see if the Safe mode is gone.
If the Safe mode label is still present, the article suggests that it may be necessary to press several keys to achieve the removal of the Safe mode label and its effect of suspending the other apps. In essence, we now move to the second discussion of entry into Safe mode:
1. Safe mode can be entered by pressing buttons at start-up. .
2. It is not known exactly which buttons were pressed but it mostly likely was the System and Home (center big button) and maybe even the Escape/Back button on the right.
3. The right combination of buttons, which supposedly are the same to enter Safe Mode, are the same to exit Safe Mode.
4. If you are certain you entered Safe Mode by accident - meaning you know you did not recently or just now installed an app that force closed Android, then you just have to find the combo to exit it.
5. Try pressing the volume buttons might clear the Safe Mode on the first reboot after initial entry into Safe Mode.
6. If the Safe Mode label disappears after pressing the volume buttons, your phone is okay.
7. If the label is still present, try rebooting the phone again.
Safe mode in Android what to do if you see that label on your screen
How to run safe mode
Try tis.
start windows > select run command > type msconfig
select BOOT.INI tab select safe boot in boot options and restart the system
this will start the system in safe boot next time re-started.
If you need further help, reach me via phone at https://www.6ya.com/expert/hee_458d01a29d21e0d3
4helpful
What is safe mode
cold y7 me safe mode dikha raha he
How do you remove the safe mode off your computer
Hi milesshoun,
To remove the safemode of your computer follow the instructions below:
First Solution:
Step 1: Click Start on your Desktop
Step 2: Click Run, type msconfig, hit enter
Step 3: Click on the "Boot" Tab and uncheck the "Safe boot" option.
Second Solution:
Check out this Video on how to remove the safe mode: Remove Safe Mode
Hope this help you ^ ^,
Webby101
2helpful
HTC phone in safe mode, can this be fixed
Hi, When you're done troubleshooting problems with your HTC Hero in Safe Mode,
you will need to go through steps to boot it regularly and remove it from Safe Mode.
To do so, turn off the phone. Then while its off, hold the Menu and Power until the phone boots. The Hero should then no longer be in Safe Mode
Start the phone and uninstall apps in safe mode
If your phone keeps restarting, or it starts up but does not display the Home screen, a recently installed application may be causing the issue.
When this happens, try starting up your phone in safe mode. In this mode, your phone does not run any third-party applications. Safe mode allows you to start up your phone successfully so you can uninstall any applications that you have recently installed or which may be stopping your phone from starting up correctly.
To start up your phone in safe mode, press the END CALL/POWER button and hold the MENU button until your phone restarts and displays the Home Screen. You will see "Safe mode" displayed at the bottom-left side of your phone screen. When your phone is in safe mode, follow the same steps in Removing installed apps to uninstall the third-party applications.
After you finish uninstalling the applications, restart your phone and check if the issue is resolved.
Hope it helped.
Thanks for using fixya....
6helpful
Please explain step by step how to reboot a computer into a safe mode?
to boot a system in safe mode restrt your computer as the computer starts press F8 you will see a set of command like safe node safemode command etc click safe mode you will see set of files running wait till the safe mode starts the you will be able to see the mouse icon then it will ask do you want the computer to start in safe mode click yes now you are in the safe mode section in safe mode section the system starts in defult setting you wont be able function somefunctions safe mode is for correctiong your computer or to remove unwanted software or hardware
I accidently removed sound when i wsa adding and removing programs
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
1helpful
2answers
2000 Infiniti radio safe mode
The Infiniti Radios don't have safe mode. I believe this is because they are a royal pain for thieves to remove and will only work with other Double DIN setups.
The radio WILL NOT going into security lock.
Grand Canyon Tech
Grand Canyon Tech
