Its old, then you found an old Vista, disk from whom?
not from HP they dont sell media kits this OLD>
some wild guess is you found some MICROSOFT disk./
and did a none HP upgrade then wonder why drivers are wrong.
sure, and do know MS shut down XP and VISTA server supportao no drivers from MS, why not go to W7 and full support? from MS?
you went from virus magnet XP dead, to VISTA dead.
why do that at all >?? vista ended, spring 2017, a fact.
lucky you,. HP page is still there, but not for long on this relic.
vista from HP.
load the top 7 here skip modem if not doing DIAL UP.
these are NOT AT MS now. only here.
https://support.hp.com/us-en/drivers/selfservice/hp-compaq-6720s-notebook-pc/3442832
First, right-click on the desktop where there are no icons and choose Display settings, may be in advanced settings, but look for supported screen resolutions.
If you pick one that is not supported, doing nothing when the screen goes wonky will automatically cause it to revert to what it was before you changed it.
One of the settings there should work for your screen.
If none work, go to your device manager and update the drivers for the display.
SOURCE: i want to install windows xp sp2
It's a relatively simply procedure, 1st download all of the necessary drivers for your laptop from Compaq's website under the support section. You'll want the drivers for Window's XP. Either burn these drivers to a CD or place them on a flash drive. Also if you already have documents or data on the laptop that you would like to keep you'll need to back that up as well to either a CD/DVD or a flash drive.
Next you'll need a Windows XP installer disk. Place the disk in your laptop and reboot. The system should prompt you, asking you if you'd like to boot off of the CD press any key. Hit any key and the computer should boot from the XP CD. The system will take a while as it loads up the installer shell. If the system does not boot from the CD you will need to go into the BIOS or CMOS and change the boot order for the computer to make the CDROM or DVD ROM the 1st boot device. The 1st prompt on the installer should be a license agreement, hit F8 to continue. The next steps will pretty much be up to you. Things like where you want to install windows XP, do you want to format the drive, etc. This sounds like your 1st install so you may want to leave everything as default. Windows should detect your Vista install and by default install it as a seperate installation allowing you to boot into either OS.
After the OS has prepared the hard disk and copied all files the computer will reboot and will boot into a installer kernel and will prompt you for even more selections. This process will take longer than the initial portion and most of these settings you can leave at default as well. When this part is complete the system will reboot again and your installation of XP should be complete.
When the system boots into windows it will ask you to create a user name, create a user name or multiple ones. Put in your driver CD or flash drive and proceed to restore your files and install your drivers. That's the revised version of it anyway.
Good Luck!
SOURCE: I AM USING HP COMPAQ 6720S WINDOWS VISTA
Yes. All the drivers are available for Xp pro. See your model link below: Install the windows the the drivers. Windows has some vidoe drivers that wil work until you install the right one.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3442833&prodTypeId=321957&prodSeriesId=3442832&swLang=8&taskId=135&swEnvOID=1093
SOURCE: I have a HP compaq 6720s and I'm trying to connect with HD TV
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
jodiki98
SOURCE: Hi, I have a HP compaq 6720s laptop, my problem is
Try downloading the drivers for the touchpad from HP website and check if it works? Is the LED light near to the touchpad on?
Testimonial: "Very quick responce and very helpful. Thank you Cathy"
