Intermatic clock motors are everywhere, but Paragon and Tork clock motors are a mystery.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
Shows manuals and resources
According to Paragon accessory chart:
http://www.paragontimecontrols.com/parts_accessories.htm
7000 series 240V clock motor M3193-71
7000 series 120V clock motor M3099-00
7008-00 is listed as 120V clock motor
http://waterheatertimer.org/pdf/Paragon-7000-series-manual.pdf
I cannot find M3099 120V clock motor on internet
Now Paragon has contact-us page for customer service:
http://www.paragontimecontrols.com/contact/default.aspx
I will also contact Paragon, and post results here if Paragon responds.
Paragon wrote back today. Nov 22 2010. They said "Invensys is still making Paragon defrost timers, but Kidde Safety who purchased Paragon is exiting Paragon Timer Control line and not making timers or parts any more. So there are no replacement parts being made. They recommended Tork timers, which you can see at: http:waterheatertimer.org/Tork-timers-and-manuals.html
SOURCE: I have a Paragon 7008-00 timer that has no trippers
Go to electricalexpeditors.com
Testimonial: "thank you very much for your responce. I had tryed the paragon website and it was very little help to me. I have found the correct trippers now."
HEATER BLOWER MOTOR
Its
faulty blower motor resistor. The low and medium speed on blower motor is
controlled by resistor and its actual speed is high. So because resistor is not
working, blower motors actual speed which is high is working.
It
can be faulty blower motor or faulty blower motor resistor. Get the blower
motor inspected. If it's faulty it has to be replaced.
For
blower motor testing and replacing, check the link below: ----
http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
These will help.
Thanks.
Get the blower motor re-inspected. If its faulty it has to be replaced.
For
blower motor testing and replacing, check the link below:----
These will help.
Thanks.
It
motor inspected.If its faulty it has to be replaced.
For
blower motor testing and replacing,check the link below:----
Blower motor Testing/replacing for all vehicles?
These will help.
Thanks.
HEATER BLOWER MOTOR
It
For
These will help.
Thanks.
Also
more help solutions recommended. Click the link below :---
Blower motor replacing for all vehicles?
----------Blower
motor Resistor shorting problem?
http://schematicsdiagram.blogspot.com/2011/12/blower-motor-resistor-shorting-problem.html
--------This will help.Thanks.
F90
F91
F92
F93
F94
F95
If lock motor runs:
1. Test continuity of wiring between EOC and lock switch on lock motor assy. Repair if needed.
2. Advance motor until cam depresses the plunger on lock motor switch. Test continuity of switch contacts. If
switch is open replace lock motor assy.
3. If motor runs and switch contacts and wiring harness test good, replace the EOC.
If lock motor does not run:
1. Test continuity of lock motor windings. Replace lock motor assembly if windings are open.
2. Test lock motor operation by using a test cord to apply voltage. If motor does not operate replace lock motor
assy.
3. If motor runs with test cord check continuity of wire harness to lock motor terminals. If harness is good replace
the EOC.
Door lock motor or latch
circuit failure
AS YOU SEE THE F93 CODE REFERES TO THE DOOR LATCH MOTOR
