I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
SOURCE: Bobbin Case
ok Sim this is a bit tricky but not to tricky first turn the handwheel toward you until the hook is at one o clock postion then slide the case without the bobbin in into the hook area you may have to work the handwheel back and forth alittle but it should slide in just remember that the case should ride in the rim. also take the needle out first that way you wont get stuck trust me it happiens.
I have a singer model 6233, same problem, bobbin case came out, can't put back in.
I have the same problem. It is a black plastic bobbin case.
On Singer 8280 I can't get bobbin case back in sewing machine
Bobbin case broke. Bought new one, but cant' seem to place it back in properly.
singer 368how can I fix bobbin case
what other product can be used? Singer?/
I CAN NOT GET THE BOBBIN CASE INTO MY SINGER SEWING MACHINE MODEL 7033
Can get casing to lock in place it keeps popping out
when we put the bobbin and case in they do not lock into place when we try to sew the bobbin and case trys to pop out singer model 9008 plastic case
When I place the bobbin case into the position "circle" of the hook, I can jiggle the bobbin case and move it.
