A fairly easy ( but messy ) fix - get a replacement tank to bowl gasket and bolt kit, shut off water supply, drain tank, remove bolts ( you might have to cut, depending on your water source and minerals in your water). Remove old gasket and clean surface with 00 grade steel wool. Replace gasket, install new bolts, remount tank.
Good luck!!
Testimonial: "that was my impression so thanks for confirming and clear explanation of whats involved."
