Hello
Your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Testimonial: "Dear Kevin... Your solution worked perfectly and washer is now ON! Thanks a million! Awesome!"
Here's what the Padlock represents:
Lock Function
You can lock the controls to prevent any selections from being made. Or you can lock the controls after you have started a cycle. children cannot accidentally start the washer by touching pads with this option selected.
To lock the washer, press and hold the DELAY START button for 3 seconds (on some models use SIGNAL button). To unlock the washer controls, press and hold the DELAY START button for 3 seconds. The control lock icon on the display will light up when it is on.
NOTE: The POWER button can still be used when the machine is locked.
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
