JRC J-NAV 500 GPS Receiver Logo
Posted on Dec 03, 2017
Have a JRC J-NAV 500 that worked fine for a short while. It will now turn on and get a valid position but will not change to any of the menu options and will not hold menu page up. Also it can only be turned off by disconnecting the power supply. Is this a simple fix? Is there anywhere in the US to get factory service?
tip
Broken Screen Delete Messages Nokia 3109 3109c 2323 2323c
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Delete Inbox Messages Blind Nokia Broken Screen
Press Central Navigation Button to get Menu
Press left once
Press up once - Message Menu
Press Central Nav Button
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Press Button above call end several times to exit from the menu
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
on Aug 06, 2010 • Cell Phones
1helpful
My JHP 500 Tranceiver will receive but not transmit, any Idea's
It may have been PLL instead of PPL. If so, that stands for Phase-Locked Loop, and is the circuit that the transmitter needs to generate the desired frequency to transmit on. That being the case, there's no user remedy and the unit must be serviced by a qualified radio shop.
4helpful
I need to reset an olympus e450 (factory setting)
1. press "menu", navigate to the icon of a camera and the number "1"
2. Nav to the option labeled "CUSTOM RESET SETTING" select the option labeled "reset"
3. Press the "OK" button. when prompted, select the option labeled "yes" and press "OK" to confirm your selection.
Cheers!
Using a cable to my pc to transmit data my jrc showed error
Yes. There used top be a download at www.jrcamerica.com but I can't find it now. I bought the required null modem cable, used the intended J-NAV LINK 2300 softaware and still got the ERROR msg. If you figure it out let me know, because loading waypints/routes is very timely.
1helpful
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
JRC Plot 500 F user manual
How can I download jrc plot 500f manual from that link?
3helpful
2answers
Jrc ff30
Wiring diagram for JRC ff30 sounder, transducer.
Top JRC GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a JRC GPS Expert? Answer questions, earn points and help others
