SOURCE: dvd stuck
Open up a paper clip until as straight as possible,
On the drive for the dvd you will see a very small hole,
With the power off, Insert the paperclip in the hole GENTLY push when you feel a resistance, and the drive will open slightly, pull gently open and remove dvd,
Happy new Year
SOURCE: DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
SOURCE: DVD PLAYER SAYS "INCORRECT DISC" AFTER "READING DISC"
LOCAL TV REPAIR SAYS THAT, WHEN THIS HAPPENS, THE DVD PLAYER NEEDS TO BE REPLACED AND WILL COST ABOUT $125 TO DO SO, WHICH IS NOT AN OPTION AS WE ONLY PAID $100 FOR THE WHOLE THING.
SOURCE: I have 2 dvd's stuck inside a Toshiba LCD TV/DVD
Take it to a service center and have them remove them. you have to take the unit apart.
SOURCE: I have dvd that stuck
I had a T.V that wouldn't allow a video eject if the top panel was locked maybe this is the same. To unlock the panel: Press and hold the VOL down
