Unpair it as there is another signal in your area on the same frequency. some frequencies can travel over a hundred meters or more. if you use a frequency monitor you will find there will be a lot of signals in your area. the original system will drown these out looking for its signal but pairing a device that has a different frequency or frequencies this can cause randone read. and will work on frequencies in this range can even be a freezer turning on etc. as every device make a signal.
SOURCE: garage door opens by itself
SOURCE: Garage door opener does not work
My Garage door goes down half the first time I'm attempting to close it; then closes completely the second try. What's the problem?
SOURCE: Chamberlain door opener--Door opens but light will not come on
If you are getting a click the relay on the board sounds like it is working. Sometimes the contacts in the light socket gets burn spots on them. Try unplugging the unit, unscrewing the bulb and with a small scrapping tool (small flat screwdriver) scrap the bottom contact and the contact on the threads. Bend the contact on the threads a little too make better contact with the bulb. Screw the bulb the bulb in completely. If this does not solve your problem the only the left to do is to replace the logic board.
