To connect a jabra 250 to the Nokia 6300: On the Nokia go to menu > settings > connectivity > bleutooth = select and the next line = visible
On the headset when it is off > push the upper button for ± 8 seconds until the lamp is burning constant and release this button.
Choose on your Nokia on the same bleutooth menu > search audio....
It will be pairing in a few seconds . It will ask if it is ok to make the connection.
The password is "0000" and push on "yes"
I hope you cann understand my english, I'am dutch.
Hi, I'll try to help you sort out your Blue tooth problem. If you want to
pair your phone with another phone, you have to disconnect your phone
from anything else it's paired to. This is because blue tooth only works
with one pairing at a time. Next you have to search for devices. When
you've found the phone you want, you need to agree a 4 digit password,
for example 0000 and put that number in both phones. You may need to
pair up in both directions to secure a successful transfer. For
example, pair your phone to your friend's phone, then pair your friend's
phone. From there you should be able to transfer songs, etc, without a
problem.
Also when you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps.
Thanks for using fixya....
