Possible that the video card has packed it in and is not responding for duel monitors
you could always try going to control panel , display section and check the settings of both monitors and the drivers for both monitors
to check the problem monitor change the setting from main display from the good unit to make the other monitor the main display
it should change over and the first monitor will then go bad
SOURCE: not otimum mode 1280x1024
Dear
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor in nearest samsung's service center.
Best regards
SOURCE: Wont work with new computer
Since this was a new out of the box computer, Safe Mode was not allowed. In order to change monitor settings (resolution), I had to use another monitor, in this case a newer CRT. With the CRT, the computer booted up, no problem. Once booted, I turned down the monitor resolution and saved. Now when the Princeton LCD was plugged in and the computer restarted, everything works fine. Now the resolution could be set to limits of the monitor.
SOURCE: Had the blank screen problem. Now it won't work above 800x600 res
The case is a PITA to pop apart, I use plastic Guitar pics to release the latches to separate the case, this works VERY well and doesn't mar the plastic on the case seam. Patience, and don't use excessive force...
Replacing the 6 Caps fixed my monitor..
Before you start, pay close attention to the orientation of the connecting Cable between boards, it's NOT Keyed. Mine had White Bands on the connectors that faced the Chassis when the Board was mounted.
There seems to be different versions of Bords depending upon production dates.
Some of these Monitors do have:
(1) 470 uf @ 10V
(3) 470 uf @ 25V
(2) 1000 uf @10V
I replaced them with:
(4) Radio Shack 272-1030 470 uf @ 35V
(2) Radio Shack 272-1032 1000 uf @35V
$8.34 Saved an Expensive monitor.
I would prefer to use Higher Quality Caps, like the Panasonic Caps from Digikey, but this worked in a pinch. The higher Voltage should make the inverter board a little More Robust.
Good Luck
SOURCE: resolution problem
reset your computer and press F8 F8 immedeatly and keep pressing untill menu appears .then highlight on enable vga mode and press enter your problem will be solved thenk you
