Hardware & Accessories Logo
Posted on Nov 17, 2010
How do I reset the clock on a Taylor timer 5891-21?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1375
Points
13
1. Press and hold the "Clock/Timer" button until you hear a beep and the time starts to flash.
2. Adjust the time using the "Hour" and "Minute" buttons. Note the clock includes AM/PM.
3. Tap the "Clock/Timer" button to restart the clock.
How do I program Taylor in/out thermometer-clock and get outside temp to register? How do I program the clock?
Hit reset next to batteries to have it sync with outside temp sensor. Push mode button to scroll thru date, time. Use up and down button on back to adjust numbers.
How do i set the clock on a taylor 5846 digital timer
Press the Mode button until you are on the clock.
Then press and hold the Start/Stop button for 3 seconds.
There should be a beep and the digits will begin to flash.
Press the Min button to increase the Hours and press the Sec button to increase the minutes.
When you have the time set, press the Start/Stop button to finalize the setting.
3helpful
How do I reset the clock on a Taylor 5846-9 kitchen timer?
4helpful
How to set the clock on a taylor 5846 Slim Digital Timer
2answers
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
15helpful
Taylor 5828
press the Hr/+ key and the Min/- key at the same time...it will reset.
4helpful
Reset timer between batches of cookies
click the Hr/+ and the Min/- keys at the same time...the timer will reset.
Top Taylor Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Taylor Hardware and Accessory Expert? Answer questions, earn points and help others
