Rethread the machine
check the top tension-try 3 or 4
change needle & make sure the needle is inserted correctly
some time the needle & thread don't work togeather--try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
