Computers & Internet Logo
Posted on Nov 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i try to set up my new 3g mobile bbroadband wireless-n router the computer ask me for a pin number that sopposed to be in the back of the router and already try all the numbers that i can found and it says me its not the pin. Can you tell me please where is the pin number location
Anonymous
Level 3:
  • Master 32,281 Answers
  • Posted on Nov 17, 2010
Anonymous
Master
Level 3:
Answers
32281
Questions
Helped
7911861
Points
102259
The PIN number could be the passphrase or encryption key code that is in the router's wireless settings. Go to the wireless router settings for this info.
When i try to set up my new 3g mobile bbroadband wireless-n router the computer ask me for a pin number that sopposed to be in the back of the router and already try all the numbers that i can found and it...
This is a common issue with Windows 7. To get around this issue, try the following steps.
  • Click the Network icon, located on the right of the taskbar near the time. It should look like a computer monitor.
  • Locate the Wireless network you want to connect to and highlight it and click connect.
  • At this point you should be given two options: "Setup the Network connection now" or "No, connect to the network anyhow.
You want to select the option for "No, connect to the network anyhow"
  • This will bypass the requirement of a PIN, which is not supplied with these routers.
asked for PIN when connecting to wireless network What should do
I cant figure out where the pin number
Are you trying to connect to the wireless network on a WINDOWS VISTA / 7 computer? Sometimes on the windows vista computer , it will ask you for the PIN number when you try to connect to the wireless network. On the same window at the bottom you will find the option " I want to connect to the network or I want to enter the key manually". If you click on that option , it will ask you for the security key.
If you don't know the security key, then you will need to check the settings of the router. You will need to open the router set up page where you can check all the wireless settings of teh router. If you want, you can also find the PIN on the wireless settings page of the router.
If you are trying to connect any other wireless device to the network and it is asking you for the PIN then you will need to open the set up page of the router and under wireless settings you will find PIN.
Click here for step by step instructions
1helpful
2answers
Pin number
you can get the pin number by contacting the provider.
Im trying to find my belkin pin number so i can have internet in my new laptop,...where can i find this?
1helpful
I need to no my 8 diget pin on my belkin router and it is not on the router
key.
find PIN.
2answers
We just added a second laptop to our home network and in setting up the laptop for wireless it asked for a pin number for our linksys wireless router but the pin number is not on the unit and we don't have...
Yes this is very straight forward
open internet explorer on your computer which is connected to wireless router.
browse to your gateway address. The default for linksys is usually http://192.168.1.1
then it will ask for username and password
linksys default username: (leave this blank)
linksys default password: admin
if that doesn't work try username: admin
password: admin
Once logged into console you should be able to see wireless security settings
Click on that and it will take you through to a page with your security settings on there you will see a wireless key or network key or wireless passphrase.
simply make a note of the key as its written. (If the password is masked or *********** out ) which is the case on some of the newer linksys devices you can simply overtype the password with a new one, bear in mind that you will have to then update any clients that normally connect to the wireless network with the new password. So thats all computers, laptops, DS's Wii's Playstations & Xbox's.
******I'd STRONGLY recommend you DO NOT change the wireless password / security key over wireless you should always do it using an RJ45 ETHERNET cable connected to your computer and the router. *********
Thanks
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
Can't remember my pin number
key.
Click here for more information about the router
and network
Device asks for passphrase or pin, what is this,(zoom 3g router)
The passphrase is used to generate the encryption code in the router's wireless configuration.
For instructions to configure the router's wireless settings ant to configure the wireless card in the laptop/computer - please click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
5helpful
How do I find the PIN number for my linksys WRT54G2 router
I have had this problem. Go to the website and get the free phone number and ring them. They were able to help me (twice as I forgot after the first time).
Top Zoom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ExpressFiX
ExpressFiX
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
