No picture or sound still, reset button will not reset the tv Tv when turned on shuts off after several seconds. no picture with sound, then the green light blinks when you push the reset button. After the blinking lights, we push the power button and sometimes the picture and sound appears and stay on as long as you want, but sometimes it takes several push of the reset button and repeating the same procedure before we get the picture and sound. We bought and installed a new lamp, and returned it for doing the same thing. We installed the old lamp and it's much better than the new one.
Can you please supply us with the make and model as well as the blink count of the green light. That count should be indicating the problem circuit. Once that info is posted, we should be able to give you more details and possible solutions.
Dan
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
It's a Mitsubishi Projection TV model WD62530, HDTV, and the blinking light after pushing the reset button is every second interval and will shut off after about 30 seconds.
i have a rca 52" projection tv and when i plug it into the wall the power button blinks in intervals of 5 then stops the continues to do the same thing over and over
