SOURCE: No Sound
First of all try getting a Symphonic remote - http://www.miracleremote.com/ not that expensive. Then you can access all areas of the TV, including all sub menus and see how the audio is set-up.. Could be you have it in SAP mode, (Second Audio Programming), in which case you will hear nothing...
Bill
SOURCE: Channel scanning fails to stop at 3.
is there an auto scan option? if so turn it off and do it manually using the up down buttons
SOURCE: symphinic SC313E cant set channels
Unplug it overnight. When you plug it back in you should get the set-up menu.
SOURCE: how do I change the
look u cant chane directly to channel 3,,,there is a solution,,jst do it mannually from the buttons available on the t.v
