Hi what is your nokia mobile exact model? If you need unlock you mobile you can visit this site Theunlockarena.com here you can get the code and unlock your mobile easily. To get the code you have to mentioned your mobile model,which country is locked now,network provider and imei number. Then they send unlock code through email. Theunlockarena.com
As we all want longer stand-by and talking times with our mobile phones and sometimes get problems to get an original battery for our old Nokias, here is a tip for this matter:
Most of the former Nokia mobile phones use the battery with the model type number "BL-4C". There are some models using type "BL-5C". This "5C" model has more capacity and could also be used instead of the "4C" model. The 5C model is slightly fatter than the 4C one. Using BL-5C needs with some Nokia mobile phone models a little modification (like 6100) while others do not (like 6260) and require a bit harder close of the battery lid. Cutting both edges on the batteries sides to fitting in the battery compartment is easy done. Charging process is not influenced and works accurate.
Hi. What is the exact model of your Nokia phone.? What kind of unlock code are you asking for? If it is a network unlock code, Only certain basic model Nokia phones can get free unlock codes.
You must provide more details to provide you a best solution. Anyway, You can visit ClassicUnlocking.Com submit your mobile make, model, country, network, IMEI number, Etc., and get the accurate unlock code at affordable cost with free unlocking guide. Good luck.
The model name of your Nokia mobile would be behind the battery not on the battery. BL-4C is the name for Nokia mobile batteries. It cannot be restricted with a code. Find out your Nokia model and get the restriction code from www.Prounlocking.com at affordable cost with easy unlocking guide. This site is a trustworthy source providing accurate unlock codes at affordable cost.
li-lon batterys like other batterys burn out over time they stop holding as much power as capable the fix is easy buy a new battery and it will restore you to full power
If you have a ViviCam, you might want to go to your local Radio Shack store, since they sell the Vivitar's and should have a Battery Compatibility Chart.
Normally a battery's "ID" (i.e. BL-4C) should be the same, no matter who's brand it is (just like with cell batteries and "button" batteries), but in recent years I noticed international manufacturers have not been following the rules.
If the voltage and current ratings on the Nokia match the ratings on your old ViviCam battery, you can use the Nokia version.
Do NOT turn it on. remove battery, bury in Tupperware bowl of rice and seal . leave 3 weeks as rice will absorb all the moisture in the phone. If you HAVE tried to turn it on, you are most likely SOL now.
