Whirlpool WFW9400S Logo
Posted on Nov 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Whirlpool front load washer WFW9400SW and I am getting an error code of F71. The washer stops , sometimes after it has been running just a few minutes.
Ginko
Level 3:
  • Whirlpool Master 19,396 Answers
  • Posted on Jan 13, 2011
Ginko
Whirlpool Master
Level 3:
Answers
19396
Questions
25
Helped
8074811
Points
55462
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
2helpful
2answers
Error code F71 on my whirlpool Model WFW9400SW02 Front Load Washer
from what i have out it is it sounds like you need a new interface board,and if theres no warantry,it will be expensive to fix.
3helpful
Code f 71
Check to see whether the laundry drum to the washer moves. If it does move, then the user interface needs replacing. If the drum is locked and will not move, you need to replace the central control unit on the washer.
Read more: Whirlpool Duet Error Code F71 ' eHow.com http://www.ehow.com/facts_7618431_whirlpool-duet-error-code-f71.html#ixzz1AANUprMm
Getting code F70 and F71.
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool Duet washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
What does F71 mean ? This comes up half way through the cycle
Regards.
Error code shows F71. door is locked and there are clothes in there soaking in water that I need to get out!! what does F71 mean and how do if solve the problem
Hi.
Sorry for the late reply.
If you get similar problems in the future, and machine gets stuck in error mode with clothes inside, empty water from tub disconnecting the drain filter, located behind a panel in front lower side of appliance. After emptying water the door will normally get opened.
Regards.
Getting code f70 & f71 washer will not run water does not fill or spin
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
Regards.
Ginko.
There is an error code f70 and there was an error code f71.
Hi.
Regards.
Ginko.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
